[Geoserver-users] shapefile tiling
Does Geoserver support Shapefile tiling? Meaning that I have multiple shapefiles that cover a geographical extent. I would like to render a map of the united states using all the Tiger dataset using the multiple shapefiles that they provide at the county level. Eventually I’ll use postGIS but I was curious as to how I would do it using just shapefiles.
thanks!
Signed,
Alessandro Ferrucci
Alessandro Ferrucci ha scritto:
Does Geoserver support Shapefile tiling? Meaning that I have multiple shapefiles that cover a geographical extent. I would like to render a map of the united states using all the Tiger dataset using the multiple shapefiles that they provide at the county level. Eventually I'll use postGIS but I was curious as to how I would do it using just shapefiles.
Nope, there is no support for tiled shapefiles a-la mapserver
Andrea Aime
OpenGeo - http://opengeo.org
On Tue, May 12, 2009 at 1:24 PM, Alessandro Ferrucci
You should be able to get more or less the same effect by adding the
shape files as individual layers and then building a layer group that
contains all the individual layers.
If you really want them all as one "real" layer your best bet would be
to import the data into a database (e.g. Postgres) and merge the
datasets into a single table there.
This message brought to you by Speed of Light Beer
When you're approaching infinite mass
It's Speed of Light time!
Not really, I don't think the data comes strictly as tiles anyway ?
You could load each Shapefile individually, possibly using a script and the REST interface, but I don't really recommend it. What we have done in the past is write a script that unpacks all the zip files, converts to psql and loads into a database. I personally have never done that for the entire US, but worked well for the tristate area.
(I would offer the script, but I think I just used "find" on the commandline).
-Arne
thanks!
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
Arne Kepp
Yeah, the end solution WILL be to load the entire U.S. data into postGIS. I was just curious as to how it would work if one did not want to work with a database and just wanted to strictly use tiled Shapefiles.
Grazie,
Alessandro Ferrucci
On Tue, May 12, 2009 at 9:45 PM, Arne Kepp <ak@anonymised.com> wrote:
Not really, I don’t think the data comes strictly as tiles anyway ?
You could load each Shapefile individually, possibly using a script and the REST interface, but I don’t really recommend it. What we have done in the past is write a script that unpacks all the zip files, converts to psql and loads into a database. I personally have never done that for the entire US, but worked well for the tristate area.
(I would offer the script, but I think I just used “find” on the commandline).
-Arne
thanks!
Kodak, there’s a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you’ll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Arne Kepp
Signed,
Alessandro Ferrucci
In case one wants that so badly, he would have to write a datastore that
can read the tiled shapefile structure (or find someone that can write
it).
Andrea Aime
