Dear all,
I'm struggling with one of those situations where Geoserver hangs up,
occupying 100% of CPU and not answering requests. In the log files I'm
getting loads of time out exceptions, but nothing special, apart the
exception reproduced below. This locked file exception is coming when
I shutdown Geoserver.
Can this exception be causing Geoserver to hang up? If not, is there a
way to avoid Geoserver permanently occupying the CPU at 100%, like
tweaking some threshold?
Thank you,
Luís
2011-05-16 10:26:02,084 ERROR [data.shapefile] - The following locker
still has a lock� read on
file:/srv/arhtapp/geoserver/data_dir/00_BDG/VECTOR/LIMITES_ADM_PTCONT/LIMITES_ARHT/LIMITES_ARHT.shp
by org.geotools.data.shapefile.shp.ShapefileReader
it was created with the following stack trace
org.geotools.data.shapefile.ShpFilesLocker$Trace: Locking
for read by org.geotools.data.shapefile.shp.ShapefileReader in thread
btpool0-51
at org.geotools.data.shapefile.ShpFilesLocker.setTraceException(ShpFilesLocker.java:72)
at org.geotools.data.shapefile.ShpFilesLocker.<init>(ShpFilesLocker.java:36)
at org.geotools.data.shapefile.ShpFiles.acquireRead(ShpFiles.java:365)
at org.geotools.data.shapefile.ShpFiles.getReadChannel(ShpFiles.java:813)
at org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:213)
at org.geotools.data.shapefile.ShapefileDataStore.openShapeReader(ShapefileDataStore.java:453)
at org.geotools.data.shapefile.indexed.IndexedShapefileDataStore.getAttributesReader(IndexedShapefileDataStore.java:458)
at org.geotools.data.shapefile.indexed.IndexedShapefileDataStore.getFeatureReader(IndexedShapefileDataStore.java:325)
at org.geotools.data.AbstractDataStore.getFeatureReader(AbstractDataStore.java:385)
at org.geotools.data.DefaultFeatureResults.reader(DefaultFeatureResults.java:210)
at org.geotools.data.store.DataFeatureCollection.openIterator(DataFeatureCollection.java:224)
at org.geotools.data.store.DataFeatureCollection.iterator(DataFeatureCollection.java:194)
at org.geoserver.feature.RetypingFeatureCollection.iterator(RetypingFeatureCollection.java:47)
at org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:1859)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1792)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:699)
at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1525)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1373)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:376)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:426)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
