we'd like to install parallel instances of geoserver (accessed via load
balancer) with a shared GEOSERVER_DATA_DIR - now, is there some kind of
listener mechanism for a geoserver instance to reload the configurations
from the xml/property files if the configuration files have changed?
If not, my first idea would be to implement a GeoServerInitializer which
starts a custom file monitor which will reload the geoserver resources if a
configuration file changed... what do you think?
Kind regards
Martin Zeller
torres.at
bestzeller.com
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Shared-configurations-on-a-cluster-with-GeoServer-2-1-RC2-tp6203453p6203453.html
Not to my knowledge.
It sure could be useful... provided you have no more than tens of layers, otherwise the reload time may turn out to be unacceptably long.
The real solution to this issue would be the Hibernate catalog, which is on the back-burner at the moment.
Luca Morandini
http://www.lucamorandini.it
I created a quick solution now with an additional
org.geoserver.config.ConfigurationListener - when an instance submits a
change the other instance makes a getGeoServer().reset() and a
getGeoServer().reload() - but nevertheless it does not work, because there
is a problem with global.xml ! The other instance cannot use anymore the
status page and cannot save to global.xml - see stack traces below (please
say if you need the whole stacktraces).
When this error occurs I have to restart the tomcat to make status page work
with both instances.
Any ideas?
Stacktrace when submitting: ****************
org.geoserver.catalog.CatalogException: Error persisting
GeoServerInfoImpl[null] to ...\data\global.xml
at
org.geoserver.config.GeoServerPersister.persist(GeoServerPersister.java:705)
at
org.geoserver.config.GeoServerPersister.handlePostGlobalChange(GeoServerPersister.java:241)
at
org.geoserver.config.impl.GeoServerImpl.fireGlobalPostModified(GeoServerImpl.java:154)
at org.geoserver.config.impl.GeoServerImpl.save(GeoServerImpl.java:141)
at org.geoserver.web.admin.ContactPage$1.onSubmit(ContactPage.java:39)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1561)
Caused by: java.io.IOException: Could not delete: ...\data\global.xml
at
org.geoserver.config.GeoServerPersister.rename(GeoServerPersister.java:665)
at
org.geoserver.config.GeoServerPersister.persist(GeoServerPersister.java:698)
Stacktrace on StatusPage: ********************
org.apache.wicket.WicketRuntimeException: Can't instantiate page using
constructor public org.geoserver.web.admin.StatusPage()
at
org.apache.wicket.session.DefaultPageFactory.createPage(DefaultPageFactory.java:212)
at
org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:57)
at
org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.newPage(BookmarkablePageRequestTarget.java:298)
at
org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.getPage(BookmarkablePageRequestTarget.java:320)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at
org.apache.wicket.session.DefaultPageFactory.createPage(DefaultPageFactory.java:192)
... 151 more
Caused by: java.lang.NullPointerException
at org.geoserver.web.admin.StatusPage.updateModel(StatusPage.java:186)
at org.geoserver.web.admin.StatusPage.(StatusPage.java:78)
torres.at
bestzeller.com
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Shared-configurations-on-a-cluster-with-GeoServer-2-1-RC2-tp6203453p6204459.html
On 03/24/2011 04:14 PM, Martin Zeller wrote:
Have you tried to just invoke a "reload" via the ReST admin interface ?
Luca Morandini
No, not yet, but I will try this. Thank you.
I found out that the error of my last post occurs with single instances
too!
I just click on "Configuration and catalog => reload" - when I go to
the
status page again the same error occurs! Maybe it is just a known bug?
constructor public org.geoserver.web.admin.StatusPage() at
at
at
at
Caused by: java.lang.reflect.InvocationTargetException at
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513) at
... 148 more Caused by: java.lang.NullPointerException at
org.geoserver.web.admin.StatusPage.updateModel(StatusPage.java:186) at
org.geoserver.web.admin.StatusPage.<init>(StatusPage.java:78) ... 153
more
On Thu, 24 Mar 2011 16:36:23 +0100, Luca Morandini
Luca Morandini
Enable your software for Intel(R) Active Management Technology to meet the
growing manageability and security demands of your customers. Businesses
are taking advantage of Intel(R) vPro (TM) technology - will your software
be a part of the solution? Download the Intel(R) Manageability Checker
today! http://p.sf.net/sfu/intel-dev2devmar
Geoserver-users mailing list
