Great! It’s working very nice in GeoServer 2.9-beta. 0/9999 is not accepted in 2.9-beta (it was accepted when provided as TIME param in 2.8.1), but 0/9998 is; so 2.9-beta solves the problem for me.
2016-03-03 19:11 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Victor,
what you are asking for is not possible in GeoServer 2.8, but you can try out
GeoServer 2.9-beta where you should be able to enter a range as the default
value. Mind however it still has to be a date range, I’m not sure 0/9999 is going
to work (you can try and see, according to the docs it might work as a reduced
accuracy time range http://docs.geoserver.org/latest/en/user/services/wms/time.html#reduced-accuracy-times)
Víctor González
http://geomati.co
On Tue, Mar 1, 2016 at 8:59 AM, Víctor González <victor.gonzalez@anonymised.com> wrote:
Hello,
I have a layer in GeoServer with time dimension: no End attribute, Presentation: List (in fact I tried other options with no luck).
I’m accessing it via WMS and I would like to show all the geometries when the TIME parameter is not provided. I tried setting the 0/9999 range as default value (Default value: Use the reference value) but the Reference value field only accepts an ISO8601 date, not a range.
If I can send a range in the TIME parameter request, shouldn’t it be possible to put it as default value as well? Is there any other approach to do this that I’m not considering?
Cheers.
Víctor González
http://geomati.co
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
