[Geoserver-users] Simple Polygon style
Hello,
I’ve been trying to style a polygon to symbolize a reservoir. First I tried a very simple polygon such as:
#d63985
It worked but it is a tiny polygon which cannot be visualized with the map starting zoom level.
So, I’ve tried an external graphic such as:
<OnlineResource
xlink:type=“simple”
xlink:href=“…/www/BMID/img/reservoir_incli.png”/>
image/png
45
This time it doesn’t show up at some zoom levels, and the initial size is not acceptable as well.
Here are my questions:
1- Is there a way to change the size of the polygon in the first example?
2- What’s the proper way to define the external graphic so it will have the proper size at all zoom levels?
Needless to say that I’ve tried several different configurations but none works as required.
Thank you for any help.
JJ.
