[Geoserver-users] SLD 1.1.0 or 1.0.0?
I've read that as part of the INSPIRE enhancement work that geoserver now
supports SLD1.1.0 and most of SE1.1, but I'm still getting some error
messages when I try and create a new style in the console using valid
(Oxygen validated) xml? SLD and Error message below:
<sld:StyledLayerDescriptor version="1.1.0"
    xmlns="http://www.opengis.net/sld&quot;
    xmlns:sld="http://www.opengis.net/sld&quot;
    xmlns:se="http://www.opengis.net/se&quot;
    xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
    xmlns:WFS_ERM="http://gdz.bkg.bund.de/wfs_erm&quot;
    xsi:schemaLocation="http://www.opengis.net/sld
    http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd&quot;&gt;
    <sld:NamedLayer>
        <se:Name>HY.PhysicalWaters.Waterbodies.Standingwater</se:Name>
        <sld:UserStyle>
            <se:Name>
HY.PhysicalWaters.Waterbodies.Standingwater.Default</se:Name>
            <sld:IsDefault>1</sld:IsDefault>
            <se:FeatureTypeStyle>
<se:Name>HY.PhysicalWaters.Waterbodies.StandingWater</se:Name>
                <se:Description>
                    <se:Title>Water bodies : Standing Water default
style</se:Title>
                </se:Description>
<se:FeatureTypeName>PhysicalWaters.Waterbodies.StandingWater</se:FeatureTypeName>
                <se:Rule>
                    <ogc:Filter>
                        <ogc:And>
                            <ogc:PropertyIsEqualTo>
<ogc:PropertyName>geomtype</ogc:PropertyName>
                                <ogc:Literal>POINT</ogc:Literal>
                            </ogc:PropertyIsEqualTo>
<ogc:PropertyName>surfacewaterclass</ogc:PropertyName>
                                <ogc:Literal>watercourse</ogc:Literal>
                        </ogc:And>
                    </ogc:Filter>
                    <se:PointSymbolizer>
                        <se:Graphic>
                            <se:Mark>
                                <se:WellKnownName>circle</se:WellKnownName>
                                <se:Fill>
                                    <se:SvgParameter
name="fill">#0066FF</se:SvgParameter>
                                </se:Fill>
                            </se:Mark>
                            <se:Size>6</se:Size>
                        </se:Graphic>
                    </se:PointSymbolizer>
                </se:Rule>
                <se:Rule>
                    <ogc:Filter>
                        <ogc:And>
                            <ogc:Or>
                                    <ogc:Literal>POLYGON</ogc:Literal>
                                    <ogc:Literal>MULTIPOLYGON</ogc:Literal>
                            </ogc:Or>
                        </ogc:And>
                    </ogc:Filter>
                    <se:PolygonSymbolizer>
                        <se:Geometry>
                            <ogc:PropertyName>geometry</ogc:PropertyName>
                        </se:Geometry>
                        <se:Fill>
                            <se:SvgParameter
name="fill">#000000</se:SvgParameter>
                        </se:Fill>
                    </se:PolygonSymbolizer>
                </se:Rule>
            </se:FeatureTypeStyle>
        </sld:UserStyle>
    </sld:NamedLayer>
</sld:StyledLayerDescriptor>
org.xml.sax.SAXParseException: cvc-complex-type.3.1: Value '1.1.0' of
attribute 'version' of element 'sld:StyledLayerDescriptor' is not valid with
respect to the corresponding attribute use. Attribute 'version' has a fixed
value of '1.0.0'.
org.xml.sax.SAXParseException: cvc-complex-type.2.4.a: Invalid content was
found starting with element 'se:Name'. One of
'{"http://www.opengis.net/sld&quot;:Name\}' is expected.
'{"http://www.opengis.net/sld&quot;:Name, "http://www.opengis.net/sld&quot;:Title,
"http://www.opengis.net/sld&quot;:Abstract,
"http://www.opengis.net/sld&quot;:IsDefault,
"http://www.opengis.net/sld&quot;:FeatureTypeStyle\}' is expected.
Perhaps I can only use SLD1.1.0 using the SLD= or SLD_Body in a getmap
request?
Thanks in advance,
Tom
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SLD-1-1-0-or-1-0-0-tp6750049p6750049.html
Hi Tom,
You are correct, at this time SLD 1.1 is not supported via the web UI, so you can’t store styles with it. It is supported via SLD and SLD_BODY parameters in a WMS request.
-Justin
On Thu, Sep 1, 2011 at 7:35 AM, tellett <thomas.ellett@anonymised.com> wrote:
I’ve read that as part of the INSPIRE enhancement work that geoserver now
supports SLD1.1.0 and most of SE1.1, but I’m still getting some error
<sld:StyledLayerDescriptor version=“1.1.0”
xmlns=“http://www.opengis.net/sld
xmlns:sld=“http://www.opengis.net/sld
xmlns:se=“http://www.opengis.net/se
xmlns:ogc=“http://www.opengis.net/ogc
xmlns:xlink=“http://www.w3.org/1999/xlink
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance
xmlns:WFS_ERM=“http://gdz.bkg.bund.de/wfs_erm
xsi:schemaLocation=“http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd”>
sld:NamedLayer
se:NameHY.PhysicalWaters.Waterbodies.Standingwater</se:Name>
sld:UserStyle
se:Name
sld:IsDefault1</sld:IsDefault>
se:FeatureTypeStyle
se:NameHY.PhysicalWaters.Waterbodies.StandingWater</se:Name>
se:Description
se:TitleWater bodies : Standing Water default
style</se:Title>
</se:Description>
se:FeatureTypeNamePhysicalWaters.Waterbodies.StandingWater</se:FeatureTypeName>
se:Rule
ogc:Filter
ogc:And
ogc:PropertyNamegeomtype</ogc:PropertyName>
ogc:LiteralPOINT</ogc:Literal>
ogc:PropertyNamesurfacewaterclass</ogc:PropertyName>
ogc:Literalwatercourse</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:PointSymbolizer
se:Graphic
se:Mark
se:WellKnownNamecircle</se:WellKnownName>
se:Fill
<se:SvgParameter
name=“fill”>#0066FF</se:SvgParameter>
</se:Fill>
</se:Mark>
se:Size6</se:Size>
</se:Graphic>
</se:Rule>
se:Rule
ogc:Filter
ogc:And
ogc:Or
ogc:LiteralPOLYGON</ogc:Literal>
ogc:LiteralMULTIPOLYGON</ogc:Literal>
</ogc:Or>
</ogc:And>
</ogc:Filter>
se:Geometry
ogc:PropertyNamegeometry</ogc:PropertyName>
</se:Geometry>
se:Fill
<se:SvgParameter
name=“fill”>#000000</se:SvgParameter>
</se:Fill>
</se:Rule>
</sld:UserStyle>
</sld:NamedLayer>
org.xml.sax.SAXParseException: cvc-complex-type.3.1: Value ‘1.1.0’ of
attribute ‘version’ of element ‘sld:StyledLayerDescriptor’ is not valid with
respect to the corresponding attribute use. Attribute ‘version’ has a fixed
value of ‘1.0.0’.
found starting with element ‘se:Name’. One of
‘{“http://www.opengis.net/sld”:Name}’ is expected.
‘{“http://www.opengis.net/sld”:Name, “http://www.opengis.net/sld”:Title,
http://www.opengis.net/sld”:Abstract,
http://www.opengis.net/sld”:IsDefault,
http://www.opengis.net/sld”:FeatureTypeStyle}’ is expected.
request?
Thanks in advance,
Tom
Special Offer – Download ArcSight Logger for FREE!
Finally, a world-class log management solution at an even better
price-free! And you’ll get a free “Love Thy Logs” t-shirt when you
download Logger. Secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsisghtdev2dev
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
