I know that GeoServer supports SLD 1.0.0, but how widespread is SLD 1.1.0 support in GeoServer? I read on http://docs.geoserver.org/latest/en/user/styling/sld-reference/ that it is partially supported, but this does not explain which SE/SLD 1.1.0 elements are supported and which are not yet.
In particular, I’d like to know if LayerFeatureConstraints is supported by GeoServer? (and if not, which alternative elements exist in SLD 1.0 or similar to use instead).
Same for NamedStyle and UserStyle, are these supported?
Best,
Jens
On Fri, May 16, 2014 at 10:58 AM, Nachtigall, Jens (init) <
Jens.Nachtigall@anonymised.com> wrote:
Only the ones that area also part of SLD 1.0, plus uom
LayerFeatureConstraints is, as far as I know, supported only if you are
using GeoServer as a feature portrayal service, providing a link to a
remote WFS
in the request. NamedStyle and UserStyle should be supposed if you are
providing a full SLD in the request (but mind that library mode can be
tricky).
That said, with the above I'm referring to SLD 1.0, I have no idea if the
SLD 1.1 can even parse those elements honestly.
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
