[Geoserver-users] SLD and support for UTF-8 for non-ASCII characters
Please refer to this image for the legend preview and disregard the link in the previous mail.
https://imgur.com/UE6khQj
I have also included the following line in the SLD
Abdul Zummerwala
On Wed, 5/30/18, abdul.zummerwala--- via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Subject: [Geoserver-users] SLD and support for UTF-8 for non-ASCII characters
Date: Wednesday, May 30, 2018, 10:01 AM
I am facing a problem with including
non-ASCII characters in the SLD file for generating the
legend.
I want to include the text -
https://imgur.com/G0dHnvV
This is how the legend previews - http://imgur.com/SREGJGo
This is included in the wrapper.conf
file
# Java Additional Parameters
wrapper.java.additional.1=-Djetty.base=.
wrapper.java.additional.2=-DGEOSERVER_DATA_DIR="%GEOSERVER_DATA_DIR%"
wrapper.java.additional.3=-Djava.io.tmpdir=./work
wrapper.java.additional.4=-Dfile.encoding=UTF-8
The OGC service global options is set
with UTF-8
My computer has the required language
pack installed: LIP_gu-IN-64bit.mlc
Any solutions?
Abdul Zummerwala
Check out the vibrant tech community on one of the world's
most
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-users mailing list
Please make sure you read the following two resources before
posting to this list:
- Earning your support instead of buying it, but Ian Turton:
http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see
this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
-----Inline Attachment Follows-----
Hi Abdul,
My first suggestion would be to verify that the fonts you're using
include glyphs for Gujarati script, and that the SLD file is actually
saved in UTF-8. (Simply writing it in the preamble doesn't help you if
the encoding is off.)
Are you writing the SLD in a text editor and pasting it in, or are you
writing it directly in the online editor?
Kristian
On Wed, May 30, abdul.zummerwala--- via Geoserver-users wrote:
Abdul Zummerwala
legend.
file
with UTF-8
Any solutions?
Abdul Zummerwala
