[Geoserver-users] SLD: calculate quinitile
Hello
I have many tables with the same structure (obviously with different data). I want to make a style that classifies the records of a column into quintiles and applies a specified color to each quintile. In this way I could use the same style for all the tables. Is it possible to generate a sld that calculates the ranges of each quintile, or should I generate it in a separate column?
Thanks
Pablo
Hi Pablo,
GeoServer has an extension called SLDService (https://docs.geoserver.org/latest/en/user/extensions/sldservice/index.html) that you can use for this kind of things.
I suggest you to have a look at that.
Mauro
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Yep, was about to say the same :slight_smile:
Just a reminder, SLDservice is an extension only on the 2.15.x series (we are going to have the first release candidate of it in a couple of weeks),
on 2.14.x and 2.13.x the functionality provided is less than described in that page and the module is provided as a community
module, so not part of releases but only found in nightly builds. A couple of links for you:
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
