Hi all
I would like to know if GeoServer 2.23.1 still ignores the SLD gap property.
I´m trying and it doesn´t work:
se:LineSymbolizer
se:Stroke
se:GraphicStroke
se:Graphic
se:ExternalGraphic
<se:OnlineResource xlink:type=“simple” xlink:href=“arrow.svg”/>
se:Formatimage/svg+xml</se:Format>
</se:ExternalGraphic>
se:Mark
se:WellKnownNamesquare</se:WellKnownName>
se:Fill
<se:SvgParameter name=“fill”>#ff0000</se:SvgParameter>
</se:Fill>
se:Stroke
<se:SvgParameter name=“stroke”>#232323</se:SvgParameter>
<se:SvgParameter name=“stroke-width”>0.5</se:SvgParameter>
</se:Stroke>
</se:Mark>
se:Size70</se:Size>
se:Rotation
ogc:Literal45</ogc:Literal>
</se:Rotation>
</se:Graphic>
se:Gap
ogc:Literal5</ogc:Literal>
</se:Gap>
</se:GraphicStroke>
</se:Stroke>
</se:LineSymbolizer>
Thanks.
Miguel Ángel.
It is indeed ignored. Generally speaking, GeoServer is built around SLD 1.0 + vendor extensions, and tends
to ignore SLD 1.1 specific bits (well, unless someone funded development geared towards supporting those extra
features, e.g., it happened for inline graphics for example).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
