[Geoserver-users] sld:pointSymbolizer error/bug
Hi GS users,
I just noticed that there is an error or possibly a bug in sld:pointSymbolizer. I used the following sld file:
<sld:FeatureTypeStyle>
        <sld:Name>name</sld:Name>
        <sld:Rule>
          <sld:Name> Low XX </sld:Name>
          <sld:Title>Low XX</sld:Title>
          <ogc:Filter>
            <ogc:PropertyIsLessThan>
              <ogc:PropertyName>var1</ogc:PropertyName>
              <ogc:Literal>10</ogc:Literal>
            </ogc:PropertyIsLessThan>
          </ogc:Filter>
          <sld:PointSymbolizer>
            <sld:Graphic>
              <sld:Mark>
                <sld:WellKnownName>circle</sld:WellKnownName>
                <sld:Fill>
                  <sld:CssParameter name="fill">#0EF078</sld:CssParameter>
                  <sld:CssParameter name="fill-opacity">0.5</sld:CssParameter>
                </sld:Fill>
                <sld:Stroke/>
              </sld:Mark>
              <sld:Size>
                <ogc:Literal>6</ogc:Literal>
              </sld:Size>
            </sld:Graphic>
          </sld:PointSymbolizer>
        </sld:Rule>
        <sld:Rule>
          <sld:Name> High XX </sld:Name>
          <sld:Title>High XX</sld:Title>
          <ogc:Filter>
            <ogc:PropertyIsGreaterThanOrEqualTo>
            </ogc:PropertyIsGreaterThanOrEqualTo>
          </ogc:Filter>
            <sld:Graphic>
              <sld:Mark>
                <sld:Fill>
                  <sld:CssParameter name="fill">#F30909</sld:CssParameter>
                </sld:Fill>
                <sld:Stroke>
                  <sld:CssParameter name="stroke-opacity">0.67</sld:CssParameter>
                </sld:Stroke>
              </sld:Mark>
              <sld:Size>
              </sld:Size>
            </sld:Graphic>
        </sld:Rule>
      </sld:FeatureTypeStyle>
I want all the points with var1>=10 to be rendered using the High XX rule. But what I noticed is that all the points where the first digit of var1 is greater than 1 are grouped and colored as High XX. For example a point with var1=5 is rendered as High XX. I also checked the geoext styler and the result is the same. So I think this should be a bug.
Has anybody else encountered this problem?
Manouchehr
On Wed, Aug 31, 2011 at 3:43 PM, Amini, Manouchehr
<Manouchehr.Amini@anonymised.com> wrote:
Hi GS users,
<sld:Rule>
<ogc:Filter>
</ogc:Filter>
<sld:Graphic>
<sld:Mark>
<sld:Fill>
</sld:Fill>
<sld:Stroke/>
</sld:Mark>
<sld:Size>
</sld:Size>
</sld:Graphic>
</sld:Rule>
<sld:Rule>
<ogc:Filter>
</ogc:Filter>
<sld:Graphic>
<sld:Mark>
<sld:Fill>
</sld:Fill>
<sld:Stroke>
</sld:Stroke>
</sld:Mark>
<sld:Size>
</sld:Size>
</sld:Graphic>
</sld:Rule>
Sounds like a data type problem, the behavior you see is compatible
with text based comparison
instead of numeric comparison.
Is the data stored in a database? If so, is var1 a text column?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Dear Andrea,
Thanks for the hint. Yes it was a data type problem.
Best,
Manouchehr
-----Original Message-----
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Sonntag, 4. September 2011 14:34
To: Amini, Manouchehr
Subject: Re: sld:pointSymbolizer error/bug
On Wed, Aug 31, 2011 at 3:43 PM, Amini, Manouchehr <Manouchehr.Amini@anonymised.com8...> wrote:
Hi GS users,
<sld:Rule>
<ogc:Filter>
</ogc:Filter>
<sld:Graphic>
<sld:Mark>
<sld:Fill>
<sld:CssParameter
<sld:CssParameter
</sld:Fill>
<sld:Stroke/>
</sld:Mark>
<sld:Size>
</sld:Size>
</sld:Graphic>
</sld:Rule>
<sld:Rule>
<ogc:Filter>
</ogc:Filter>
<sld:Graphic>
<sld:Mark>
<sld:Fill>
<sld:CssParameter
</sld:Fill>
<sld:Stroke>
<sld:CssParameter
</sld:Stroke>
</sld:Mark>
<sld:Size>
</sld:Size>
</sld:Graphic>
</sld:Rule>
Sounds like a data type problem, the behavior you see is compatible with text based comparison instead of numeric comparison.
Ing. Andrea Aime
Tech lead
