[Geoserver-users] SLD PropertyIsEqualTo filter with matchcase
hello all,
i'm using GeoServer 1.6.4b and am trying to use a WFS GetFeature request
with a filter that ignores the case of a feature string property but so
far unsuccessfully. may be a GeoServer developer or a more experienced
user can help:
using the Sample Request page on GeoServer's GUI, after selecting the
WFS_getFeature-1.0.xml Request drop-down item, and replacing the FID
filter with a PropertyIsEqualTo (xml follows), both cases of
matchcase="0" and "1" fail returning the state.
<wfs:GetFeature service="WFS" version="1.0.0"
  outputFormat="GML2"
  xmlns:topp="http://www.openplans.org/topp&quot;
  xmlns:wfs="http://www.opengis.net/wfs&quot;
  xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
  <wfs:Query typeName="topp:states">
    <ogc:Filter>
       <PropertyIsEqualTo matchcase="0">
          <PropertyName>STATE_NAME</PropertyName>
          <Literal>DELAWARE</Literal>
       </PropertyIsEqualTo>
    </ogc:Filter>
    </wfs:Query>
</wfs:GetFeature>
is this a known problem or i'm doing something wrong? if it's the
former, is there a known workaround?
TIA + cheers;
rsn
Hi Raif,
A couple of things. First case sensitivity is technically only available in wfs 1.1. Although I believe GeoServer should respect it in a 1.0 request. Second, case sensitivity is unfortunately only available with postgis. Which backend are you using?
Raif S. Naffah wrote:
hello all,
i'm using GeoServer 1.6.4b and am trying to use a WFS GetFeature request with a filter that ignores the case of a feature string property but so far unsuccessfully. may be a GeoServer developer or a more experienced user can help:
using the Sample Request page on GeoServer's GUI, after selecting the WFS_getFeature-1.0.xml Request drop-down item, and replacing the FID filter with a PropertyIsEqualTo (xml follows), both cases of matchcase="0" and "1" fail returning the state.
  outputFormat="GML2"
    <ogc:Filter>
    </ogc:Filter>
    </wfs:Query>
</wfs:GetFeature>
is this a known problem or i'm doing something wrong? if it's the former, is there a known workaround?
TIA + cheers;
rsn
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
hello Justin,
thanks for your prompt reply! i was testing with a shapefile-based
feature but i next tried with a PostgreSQL/PostGIS one, both with WFS
1.0 and 1.1 and matchcase values "0", "1", "true" and "false".
unfortunately i still do not get the right feature so it looks like
it's not working with both types of data-stores.
On Thu, 12 Feb 2009 02:42:14 am Justin Deoliveira wrote:
Hi Raif,
> hello all,
> outputFormat="GML2"
> <ogc:Filter>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> TIA + cheers;
> rsn
>----------- Create and Deploy Rich Internet Apps outside the browser
> with Adobe(R)AIR(TM) software. With Adobe AIR, Ajax developers can
> use existing skills and code to build responsive, highly engaging
> applications that combine the power of local resources and data
> with the reach of the web. Download the Adobe AIR SDK and Ajax docs
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
cheers;
rsn
Hi Raif,
Looking at the original request I just noticed something. IT has be specified as "matchCase", rather than "matchcase". Too much case-insensitivity going on ;). Try that and let me know if it works.
-Justin
hello Justin,
thanks for your prompt reply! i was testing with a shapefile-based feature but i next tried with a PostgreSQL/PostGIS one, both with WFS 1.0 and 1.1 and matchcase values "0", "1", "true" and "false". unfortunately i still do not get the right feature so it looks like it's not working with both types of data-stores.
Hi Raif,
hello all,
  outputFormat="GML2"
    <ogc:Filter>
    </ogc:Filter>
    </wfs:Query>
</wfs:GetFeature>
TIA + cheers;
rsn
Justin Deoliveira
hello Justin,
thanks again for your quick turn-around!
On Thu, 12 Feb 2009 03:04:04 pm Justin Deoliveira wrote:
Hi Raif,
you probably meant the other way around :wink:
Too much
when i try with matchCase i get:
* WFS 1.0, matchCase="false", for both shapefile- and postgis-
based features:
<ServiceException>
      java.lang.RuntimeException: Parsing failed for PropertyIsEqualTo: java.lang.ClassCastException: java.lang.String cannot be cast to
java.lang.Boolean
Parsing failed for PropertyIsEqualTo: java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Boolean
Details:
org.geoserver.platform.ServiceException: java.lang.RuntimeException: Parsing failed for PropertyIsEqualTo: java.lang.ClassCastException:
  at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1177)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:198)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:170)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
* the same above but with the value of the matchCase attribute without
the quotes, as would be expected, throws a different exception. here
are the first few lines:
<ServiceException>
   Open quote is expected for attribute "matchCase" associated with an element type "PropertyIsEqualTo".
* WFS 1.1, matchCase="false", with both shapefile- and postgis-
based features work and return the expected result! so this could
be the work-around i need.
thank you muchly for your help!
off the top of your head, do you know if later versions of GeoServer
handle the matchCase attribute correctly for WFS 1.0?
-Justin
> hello Justin,
>> Hi Raif,
>>> hello all,
>>> outputFormat="GML2"
>>> <ogc:Filter>
>>> </ogc:Filter>
>>> </wfs:Query>
>>> </wfs:GetFeature>
>>> TIA + cheers;
>>> rsn
cheers;
rsn
