[Geoserver-users] SLD reprojection issue
Hi list,
does anyone have an idea why the following request (an SLD with a BBOX
filter in EPSG:900913, probably native dataset in EPSG:4326) does not work
(empty image whereas selection expected)? It works fine when using a
similar BBOX filter in the native projection of the dataset (EPSG:4326).
The SLD used is:
<sld:StyledLayerDescriptor xmlns:sld="http://www.opengis.net/sld&quot;
version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
xmlns:gml="http://www.opengis.net/gml&quot;&gt;&lt;sld:NamedLayer&gt;&lt;sld:Name&gt;topp:tasmania\_water\_bodies&lt;/sld:Name&gt;&lt;sld:UserStyle&gt;&lt;sld:Name&gt;default&lt;/sld:Name&gt;&lt;sld:FeatureTypeStyle&gt;&lt;sld:Rule&gt;&lt;ogc:Filter
xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;&lt;ogc:BBOX&gt;&lt;ogc:PropertyName&gt;the\_geom&lt;/ogc:PropertyName&gt;&lt;gml:Box
srsName="EPSG:900913"><gml:coordinates decimal="." cs="," ts="
">16237781.240227,-5319824.9118939
16308714.802466,-5247668.3572028</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:PolygonSymbolizer><sld:Fill><sld:CssParameter
name="fill">#FF0000</sld:CssParameter></sld:Fill></sld:PolygonSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer></sld:StyledLayerDescriptor>
Full GetMap url:
http://demo.opengeo.org/geoserver/wms?LAYERS=topp%3Atasmania_water_bodies&FORMAT=image%2Fgif&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&SLD_BODY=<sld%3AStyledLayerDescriptor%20xmlns%3Asld%3D"http%3A%2F%2Fwww.opengis.net%2Fsld"%20version%3D"1.0.0"%20xsi%3AschemaLocation%3D"http%3A%2F%2Fwww.opengis.net%2Fsld%20http%3A%2F%2Fschemas.opengis.net%2Fsld%2F1.0.0%2FStyledLayerDescriptor.xsd"%20xmlns%3Axsi%3D"http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance"%20xmlns%3Aogc%3D"http%3A%2F%2Fwww.opengis.net%2Fogc"%20xmlns%3Agml%3D"http%3A%2F%2Fwww.opengis.net%2Fgml"><sld%3ANamedLayer><sld%3AName>topp%3Atasmania_water_bodies<%2Fsld%3AName><sld%3AUserStyle><sld%3AName>default<%2Fsld%3AName><sld%3AFeatureTypeStyle><sld%3ARule><ogc%3AFilter%20xmlns%3Aogc%3D"http%3A%2F%2Fwww.opengis.net%2Fogc"><ogc%3ABBOX><ogc%3APropertyName>the_geom<%2Fogc%3APropertyName><gml%3ABox%20xmlns%3Agml%3D"http%3A%2F%2Fwww.opengis.net%2Fgml"%20srsName%3D"EPSG%3A900913"><gml%3Acoordinates%20decimal%3D"."%20cs%3D"%2C"%20ts%3D"%20">16237781.240227%2C-5319824.9118939%2016308714.802466%2C-5247668.3572028<%2Fgml%3Acoordinates><%2Fgml%3ABox><%2Fogc%3ABBOX><%2Fogc%3AFilter><sld%3APolygonSymbolizer><sld%3AFill><sld%3ACssParameter%20name%3D"fill">%23FF0000<%2Fsld%3ACssParameter><%2Fsld%3AFill><%2Fsld%3APolygonSymbolizer><%2Fsld%3ARule><%2Fsld%3AFeatureTypeStyle><%2Fsld%3AUserStyle><%2Fsld%3ANamedLayer><%2Fsld%3AStyledLayerDescriptor>&BBOX=16280475.86625,-5322462.8128125,16593561.934062,-5009376.745&WIDTH=256&HEIGHT=256
TIA.
Best regards,
Bart
I'm not sure why, but usual suspects are the gml being encoded in a
mixin of GML2 and GML3 formats and confusing the parser, or GeoServer
not reprojecting to native crs.
On Tue, 2011-03-22 at 10:43 +0100, Bart van den Eijnden (OSGIS) wrote:
Hi list,
The SLD used is:
Full GetMap url:
TIA.
Best regards,
Bart
Enable your software for Intel(R) Active Management Technology to meet the
growing manageability and security demands of your customers. Businesses
are taking advantage of Intel(R) vPro (TM) technology - will your software
be a part of the solution? Download the Intel(R) Manageability Checker
today! http://p.sf.net/sfu/intel-dev2devmar
Geoserver-users mailing list
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
On Tue, Mar 22, 2011 at 11:34 AM, Gabriel Roldán <groldan@anonymised.com> wrote:
I also recently fixed a problem with the renderer not drawing small
lines and polygons
in a projected srs. The fix is in the nightlies but not in 2.1RC2
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 333 8128928
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
