Dear VIlle,
if you have experience in GeoServer and plan to stick with it, my suggestion is CSS; while it is geoserver specific it is much more compact than SLD and mostly equivalent.
The geoserver editor has also been improved lately to be more user friendly.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Wed, Nov 7, 2018 at 2:41 PM Ville Koivisto <ville.koivisto@anonymised.com> wrote:
Dear list,
I need start working on with a bunch of styling with different layers. Knowing Geoserver, alternatives are either SLD or CSS. Could someone more experienced please enlighten me, what might be the most efficient way of producing SLD styles when number of styled layers is high?
Should I start learning CSS and go with that?
Should I produce SLD styles with QGIS and then repair their mismatches which are caused by version conflict? Or just start writing them in Geoserver panel? Use Udig that can produce SLD 1.0.0 as I’ve heard?
Thanks in advance.
Kind regards,
Ville Koivisto
+35840 701 4283
GIS Expert
Suomen kuntotekniikka Oy
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
