[Geoserver-users] SLD: Use variable substitution for transform function (like interpolate)
Hello,
I posted the relevant part of my SLD at the bottom. I wonder if I can use
geoserver variable substitution to pass the threshold values (like -9999, 0,
1.5) in my WMS url.
The examples I saw with variable substitution always refer to a constant
literal (like size):
<ogc:Function name="env">
   <ogc:Literal>size</ogc:Literal>
</ogc:Function>
But in this case I think I actually have to change that literal? Any ideas?
Thanks!
<CssParameter name="stroke">
  <ogc:Function name="Interpolate">
       <ogc:PropertyName>VALUE</ogc:PropertyName>
       <ogc:Literal>-9999</ogc:Literal>
       <ogc:Literal>#000000</ogc:Literal>
       <ogc:Literal>0</ogc:Literal>
       <ogc:Literal>#A51C1C</ogc:Literal>
       <ogc:Literal>1.5</ogc:Literal>
       <ogc:Literal>#FF9A9A</ogc:Literal>
       <ogc:Literal>#00FF00</ogc:Literal>
       <ogc:Literal>color</ogc:Literal>
  </ogc:Function>
</CssParameter>
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-Use-variable-substitution-for-transform-function-like-interpolate-tp5259323.html
if I understand the question correctly, you can pass a second parameter
to env, which will provide a default value, so that you are not forced
to pass the env variable in all GetMap calls:
<ogc:Function name=“env”>
ogc:Literalsize</ogc:Literal>
ogc:Literal10</ogc:Literal>
</ogc:Function>
Also see the documentation:
http://docs.geoserver.org/2.8.x/en/user/styling/sld-extensions/substitution.html
On Sat, Apr 2, 2016 at 7:26 PM, hanshupe <paul.schneeweiss@anonymised.com> wrote:
Hello,
1.5) in my WMS url.
</ogc:Function>
Thanks!
VALUE -9999 #000000 0 #000000 0 #A51C1C 1.5 #FF9A9A 1.5 #00FF00 color
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785471&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hello,
Sorry if I was unclear, my problem is that I want to apply variable
substitution for this sld part:
In the geoserver examples there is a fixed literal (like size), which value
is set by variable substitution. But in my sld code with the transformation
function I don't have this fixed literal, but input/output pairs
(value/color) and I want to specify the threshold values (e.g. -9999, 0,...)
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-Use-variable-substitution-for-transform-function-like-interpolate-tp5259323p5259328.html
Ok it's solved, I didn't know that I can just define my own parameter name
and put it inside the literal. Thanks!
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-Use-variable-substitution-for-transform-function-like-interpolate-tp5259323p5259329.html
