[Geoserver-users] Slicing geoserver data directory
Hi List,
is it possible to slice the data directory, like having the actual data separated from all the other config-files?
Thx and regards
Andreas
Hi Andreas,
it is actually advisable :slight_smile:
By default data stay inside the data directory so the config + the data is portable easily.
In real enterprise systems we tend to separate them.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Ok, ruper. Can you tell me what I need to do? In th e documentatio it is only mentioned how to externalize your data directory.
Thx and regards
Andreas
Am 02.10.2020 um 12:37 schrieb Simone Giannecchini:
Hi Andreas,
Simone Giannecchini
@simogeo
Founder/Director
On Fri, Oct 2, 2020 at 12:16 PM Andreas Böhme <andreas.boehme@anonymised.com> wrote:
Hi List,
Thx and regards
Andreas
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.coms.sourceforge.net
Andreas Böhme
Techniker/Technician
Landschaftsökologie/Computational Landscape Ecology
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Helmholtz Centre for Environmental Research GmbH - UFZ
Permoserstraße 15, 04318 Leipzig, Germany
Phone +49 341 235 1058
[andreas.boehme@anonymised.com](mailto:andreas.boehme@anonymised.com...), [www.ufz.de](http://www.ufz.de)
Sitz der Gesellschaft/Registered Office: Leipzig
Registergericht/Registration Office: Amtsgericht Leipzig
Handelsregister Nr./Trade Register Nr.: B 4703
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: N.N.
Wissenschaftlicher Geschäftsführer/Scientific Managing Director:
Prof. Dr. Georg Teutsch
Administrative Geschäftsführerin/Administrative Managing Director:
Dr. Sabine König
Vermeiden Sie unnötige Ausdrucke./Think before printing.
Informationen aus der Wissenschaft (z.B. Veranstaltungshinweise, Projektangaben, Publikationen,
Bücher)
Hi Andreas,
unfortunately there is no simple way to move files.
You either move them and reconfigure layers via the GUI or (risky, so backup the data dir) you can move the data and then change the path directly on the configuration on disk (inside the xml files) and then restart geoserver.
Simone Giannecchini
@simogeo
Founder/Director
A couple options:
  • Use absolute paths (to a network share or fast disk or where your actual data lives)
  • Experiment with “geosever-environment.properties” as outlined here to avoid typing in the same absolute paths each time
Jody Garnett
Hi Jody,
Related to the second suggestion… is the Backup and Restore community module required to use the catalog parametrization?
Jim
On 10/6/2020 1:38 AM, Jody Garnett wrote:
A couple options:
Jody Garnett
On Fri, 2 Oct 2020 at 04:51, Andreas Böhme <andreas.boehme@anonymised.com> wrote:
Thx and regards
Andreas
Hi Andreas,
Simone Giannecchini
@simogeo
Founder/Director
Hi List,
Thx and regards
Andreas
Andreas Böhme
[andreas.boehme@anonymised.com](mailto:andreas.boehme@anonymised.com), [www.ufz.de](http://www.ufz.de)
Dr. Sabine König
Bücher)
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
The functionality moved to core.
The docs are here: https://docs.geoserver.org/latest/en/user/community/backuprestore/configtemplate.html (and have not yet been moved).
Jody Garnett
