[Geoserver-users] Small study on "Cloud optimized OGC WMS Servers"
For a small project as part of the Swiss National Geodata Infrastructure (grant project) several people worked on a study document called “Cloud-optimized OGC WMS Server” where we analyzed problems that can arise when you install an OGC web server in the cloud (e.g. docker image deployed via Kubernetes, OpenShift or the likes). This work had a focus on QGIS Server with it’s own set of problems - but some of the issues studied in this document also matter for other OGC WMS servers, like UMN Mapserver or Geoserver, such as the load balancing problem, how to share resources, etc.
Here is the link to the document (not in final form yet, but close to being final): https://docs.google.com/document/d/1cOUWgzalRx7CHWTFgHz6-uyScsCcoaEmYC0VBHdZShQ/edit#heading=h.c7gq4lie7ys2
I wonder if any similar work has been done specifically around problems, challenges and solutions when you deploy Geoserver in cloud environments? Do you know of any work?
We came across this project here: http://geoserver.org/geoserver-cloud/ - this is probably the closest system compared to what we have in mind. Can you share a bit of experience with this system? How well does it work in practice? What are the challenges/problems and what works well?
One major problem that probably all installations of an OGC WMS server have is how to deploy a more intelligent load balancing system? (the “Gateway” in the above mentioned Geoserver system architecture diagram). Often, the default load balancer is some kind of round robin load balancer system, but this frequently leads to inferior results where “cheap and short” requests (such as a simple GetFeatureInfo or GetLegendGraphics request) can be queued behind a long-running GetMap request or PDF generation task (potentially with many layers, many features and a high-dpi, such as 600dpi, where the request can take several seconds to process. Meanwhile, the GetFeatureInfo might still wait behind a long-running request, while parallel instances would have free resources, because they have just finished their own task.
As mentioned in our study document it is of course possible to separate the requests to dedicated instances for short requests and potentially long requests, to avoid the above mentioned scenario, but we are not so satisfied with the solution, as it is a bit inflexible and also a bit harder to maintain. Ideally, we would like to have a more intelligent load balancer with incoming queue that holds back requests as long as all WMS server instances are busy. This would avoid the situation where a “less intelligent” load balancer would simply forward the requests to instances based on Round-Robin principle.
Do you know of any additional work in the Geoserver community regarding cloud deployment, cloud optimization, intelligent load balancing and resource sharing?
In our study document I’d like to also include the perspective of other WMS servers besides QGIS server, so any input would be welcome.
Andreas
Andreas Neumann
QGIS.ORG board member (treasurer
Andreas Neumann
QGIS.ORG board member (treasurer)
