[Geoserver-users] Source for Geotools 2.2.3-SNAPSHOT
I’m trying to locate a problem I have with Geoserver 1.4.1 WMS. This seems to be located inside the Geotools code. I can’t easily find the source code for your 2.2.3-SNAPSHOT of Geotools. Is this available from some location or do I have to download the 2.2.x-branch from Subversion? Or is one of the tags in subversion the same as your 2.2.3-SNAPSHOT version?
Any hints appreciated.
Steinar Hansen
Steinar Hansen ha scritto:
I'm trying to locate a problem I have with Geoserver 1.4.1 WMS. This seems to be located inside the Geotools code. I can't easily find the source code for your 2.2.3-SNAPSHOT of Geotools. Is this available from some location or do I have to download the 2.2.x-branch from Subversion? Or is one of the tags in subversion the same as your 2.2.3-SNAPSHOT version?
You should be able to download 2.2.x branch, it did not receive many changes since the 1.4.1 release (unfortunately by mistake Geoserver has been released without even tagging geotools... sigh..).
If you come up with a patch, let us know.
Out of curiosity, have you tried Geoserver 1.5.0, just released?
Oh, if you need assistance, you can stop by the GeoServer irc channel
on irc.freenode.net and make questions, usually at least one of us is hanging there.
