On Wed, Oct 21, 2015 at 5:57 PM, Jair Santos <jsantos5954@anonymised.com> wrote:
I apologize for asking this question here, which I believe is more Tomcat
than Geoserver, but I am sure that you guys are able to help. Please go
easy on me.
Tomcat can serve the index.html file located in C:\Program Files\Apache
Software Foundation\Tomcat 8.0\webapps\geoserver, but it cannot serve any
other file (see log below). I know there are a list of welcome files in
web.xml such as
welcome-file-list>
<welcome-file>index.html</welcome-file>
</welcome-file-list>.
Even including for example the index_backup.html in the welcome-file-list
it returns 404.
I’ve checked the permissions of the geoserver folder and the files inside
it. They seems to be okay.
I have vague memories, but as far as I remember we have security checks to
disallow access
to the data directory embedded in the war file (the default one).
If you want to publish static files you should be able to put them in the
www subfolder of
your data directory, and they will show up at http://host:port
/geoserver/www/yourfile.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
