Hi Justin.
Thanks for your answer.
If I understand correctly, the only “official” possibility (from a user perspective, not a programmer) would be to install a 32-bit JRE on Windows 2008 R2 64-bit, used by Tomcat and GeoServer, and everything would be fine, but we wouldn’t benefit from 64-bit architecture, right?
Pedro Briones Garcia
Grupo Tragsa - SEPI
Regards.
/FIRMA%20OUTLOOK/Tragsatec.png)
/FIRMA%20OUTLOOK/cenefa.png)
/FIRMA%20OUTLOOK/Tragsatec_SEPI.png)
Calle Julián Camarillo 6 B - 28037 Madrid
Tel.: 913226489 - 88216 - Fax: 913226005
pbg@anonymised.com
www.tragsa.es
En beneficio del medio ambiente, imprime este e-mail sólo si realmente es necesario
For the benefit of the environment, print this e-mail only if you really need
De: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Enviado el: jueves, 18 de septiembre de 2014 15:58
Para: Pedro Briones Garcia
CC: geoserver-users@anonymised.comurceforge.net
Asunto: Re: [Geoserver-users] SpatiaLite extension in Windows 2008 R2 64-bit
Unfortunately there is no current solution for Windows 64 bit. I couldn’t figure out how to get a proper working Windows 64 bit compiler so I eventually gave up on that platform. What is needed is for someone to compile all the necessary libraries on that platform. The project that builds out everything is here:
https://bitbucket.org/jdeolive/sqlite-jdbc/
2014-09-18 7:36 GMT-06:00 Pedro Briones Garcia <pbg@anonymised.com>:
Hello everyone.
Can anyone tell me if it is possible to use the SpatiaLite extension in GeoServer in a Windows Server 2008 R2 64-bit server with TomCat?
When I install this extension, only one option is shown: spatialite (JNDI) connection
Is there any workaround to make it work?
Thanks in advance.
Un saludo
Jefe de Grupo de Actuaciones y Proyectos
Gerencia de Sistemas de Información Geográfica
Grupo Tragsa - SEPI
pbg@anonymised.com www.tragsa.es
********************************************************************************************** El consumo de papel es perjudicial para el medio ambiente. Por favor, téngalo en cuenta antes de imprimir este mensaje. AVISO LEGAL: Este mensaje y sus anexos pueden contener información confidencial o legalmente protegida. Está dirigido únicamente a la persona o entidad indicada como destinatarios del mensaje. Si este mensaje le hubiera llegado por error, por favor elimínelo sin revisarlo ni reenviarlo y notifíquelo inmediatamente al remitente. **********************************************************************************************
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce
Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Justin Deoliveira
VP Engineering | Boundless
@boundlessgeo
