[Geoserver-users] specify grid resolution WCS getCoverage request
WCS 2.0 does not support resx and resy like WCS 1.0.0 did. If WCS 2.0 server supports the scaling extension you can read from https://portal.opengeospatial.org/files/?artifact_id=54504 how to change resolution. Core standard does not include scaling and that’s why you did not find it. Foprtunately Geoserver seems to support scaling: http://localhost:8080/geoserver/ows?service=WCS&version=2.0.1&request=GetCapabilities
ows:Profile
http://www.opengis.net/spec/WCS_service-extension_scaling/1.0/conf/scaling
</ows:Profile>
-Jukka Rahkonen-
Alberto Callejas Delgado wrote:
I am trying to get a coverage in ArcGrid format but changing the default gridoffsets.
Inline images 1
I have tried:
http://host:8080/geoserver/myworkspace/wcs?service=WCS&version=2.0.1&request=GetCoverage&coverageid=myworkspace:mylayer&CRS=EPSG:4326&bbox=-2.377383999999996,55.60870599999999,-2.366658999999996,55.61303499999998&resx=6.422155688622945E-5&resy=-6.422155688622945E-5&format=ArcGrid
I got the same default cellsize values.
I have read the WCS core documentation but could not find the way to make it works.
Any help or pointing direction would be much appreciated.
Best,
Alberto
Thanks for your answer!
You are right, I did the getcapabilities request and get some profile extensions to the WCS 2.0.1 core, and definitely got that one!
I will take a look to the document you suggest and let you know how it goes.
Thank you!
On 18 May 2016 at 11:28, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
ows:Profile
</ows:Profile>
-Jukka Rahkonen-
Inline images 1
I have tried:
Best,
Alberto
