I have noticed that the GetFeatureInfo request created by the
application/openlayers format makes a URL WMS request that has parameters
that are both upper and lowercase (see the example request below: SRS/srs ,
LAYERS/layers , STYLES/styles).
While this doesn't seem to cause an error I am wondering which parameter is
used when both occur but have different values (and whether the
application/openlayers format should be creating a URL like this...)
- Tyler
Example URL created by the application/openlayers page:
http://geoserver:8085/geoserver/wms
?WIDTH=800
&LAYERS=topp%3Astates
&STYLES=
&SRS=EPSG%3A4326
&HEIGHT=317
&FORMAT=image%2Fpng
&SERVICE=WMS
&VERSION=1.1.1
&REQUEST=GetFeatureInfo
&EXCEPTIONS=application%2Fvnd.ogc.se_xml
&BBOX=-145.489487%2C17.494456%2C-46.211784%2C56.833246
&X=484&Y=106
&INFO_FORMAT=text%2Fhtml
&QUERY_LAYERS=topp%3Astates
&FEATURE_COUNT=50
&layers=topp%3Astates
&styles=
&srs=EPSG%3A4326
View this message in context: http://www.nabble.com/specifying-both-uppercase-and-lowercase-parameters-in-WMS-requests-tp15511633p15511633.html
Tough to say. My guess would be the last copy of the parameter since its the last to get parsed by the dispatcher and registered under a case insensitive way. Regardless this is a bug. Tyler, can you open a jira for this one?
- Tyler
?WIDTH=800
&STYLES=
&SRS=EPSG%3A4326
&HEIGHT=317
&FORMAT=image%2Fpng
&SERVICE=WMS
&VERSION=1.1.1
&X=484&Y=106
&FEATURE_COUNT=50
&styles=
&srs=EPSG%3A4326
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Created:
http://jira.codehaus.org/browse/GEOS-1753
- Tyler
?WIDTH=800
&STYLES=
&SRS=EPSG%3A4326
&HEIGHT=317
&FORMAT=image%2Fpng
&SERVICE=WMS
&VERSION=1.1.1
&X=484&Y=106
&FEATURE_COUNT=50
&styles=
&srs=EPSG%3A4326
Tyler A. Erickson, Ph.D.
Research Scientist
Michigan Tech Research Institute
3600 Green Court, Suite 100
Ann Arbor, MI 48105
tyler.erickson@anonymised.com
www.mtri.org
www.michiganview.org
