We have a plug-in for GeoServer that connects GeoServer roles to an RBAC service. Currently, we set up the connection URL required to reach the service during initial deployment, which works well. However, we are switching to a service discovery mechanism and need the values to be replaceable at runtime with Spring Framework properties or environment variables.
Does the GeoServer security subsystem do property replacements when reading the config.xml file?
Example configuration
RBAC_ROLE
com.company.security.RBACRoleService
${rbac.httpPrefix}://${rbac.ip}:${rbac.port}/
ROLE_GEOADMIN
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Direct (719) 452-7257
Hi Chris
Property replacements are not supported. I never tried it but I am quite sure.
Christian
On Fri, Nov 7, 2014 at 4:26 PM, Chris Snider <chris.snider@anonymised.com> wrote:
RBAC_ROLE
ROLE_GEOADMIN
Chris Snider
![Description: Description: Description: cid:image001.png@anonymised.com]()
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Thanks Christian,
I had tried regular property values and they are NOT supported, but didn’t know if there was an additional configuration I had to set.
Chris Snider
![Description: Description: Description: cid:image001.png@...5633...]()
Hi Chris
Christian
On Fri, Nov 7, 2014 at 4:26 PM, Chris Snider <chris.snider@…3225…> wrote:
RBAC_ROLE
ROLE_GEOADMIN
Chris Snider
