[Geoserver-users] SQL Server Store creation problem
We are using GeoServer 2.0.1 with the SQL Server plugin. When we create a SQL server store with database field populated with the database name, we get an error
Original exception error:
Unable to obtain connection: Cannot create PoolableConnectionFactory (The port number 1433/the-db-name is not valid.)
If i have the database name removed, I am able to go to create a new layer but a list of layers that doesn’t bind with the data in the table (which is expected since I never point to the scheme).
Any clue? We are in the process of setting this up the first time, so never had a working version before. Is this a common problem in SQL or something in SQL settings that need to be corrected.
The test data in the table is geonames data, just want to test out this server but no luck with sql so far.
Best Regards,
Sai
Hi Sai,
So you do get some layers back but not the ones you want? What layers is the server actually returning to you? In a "global" database, some other database, etc...
-Justin
On 1/24/10 9:08 PM, Chow, Sai wrote:
we get an error
layer but a list of layers that doesn't bind with the data in the table
Best Regards,
Sai
Throughout its 18-year history, RSA Conference consistently attracts the
world's best and brightest in the field, creating opportunities for Conference
attendees to learn about information security's most important issues through
interactions with peers, luminaries and emerging and established companies.
http://p.sf.net/sfu/rsaconf-dev2dev
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin,
When I remove the database and scheme field from the data store properties, I have the following layers:
spt_fallback_db
spt_fallback_dev
spt_fallback_usg
spt_monitor
spt_values
I guess they are from the global database? The problem is that, when I put in the "database" property in the database store, I get an error of invalid port number, could this be a bug of some sort since the exception is thrown before an actual connection is established.
Sai
On Jan 25, 2010, at 9:03 AM, Justin Deoliveira wrote:
Hi Sai,
database, etc...
-Justin
we get an error
Best Regards,
Sai
Justin Deoliveira
Hi Sai,
Are these tables in any way "connected" to the user you are logging in as?
Anyways, people have got this to work before so I know it is possible to load the desired tables. However not being able to specifying the database and schema directly is an issue that has been outstanding for quite some time. I will try to look deeper into how exactly the jdbc driver is connecting to the database to see if i can make the connection process a little easier.
-Justin
On 1/25/10 10:47 AM, Chow, Sai wrote:
Justin,
spt_fallback_db
spt_fallback_dev
spt_fallback_usg
spt_monitor
spt_values
Sai
Hi Sai,
database, etc...
-Justin
we get an error
Best Regards,
Sai
Justin Deoliveira
Justin Deoliveira
Justin,
Not that I know of. This user have access to two different databases on the same host. Only one database have one table that contains some geonames US import for testing purposes. It seem that no matter what database name I put in, it thrown an exception of invalid port number "1433/whatever-db-name". It almost sounds like the connection string format might be invalid? I'm using SQL 2008 with the JDBC 2.0 driver. sqljdbc4.jar in my web-inf/lib, removed all other sqljdbc.jar files. So I believe I'm using the correct driver. When I use the sqljdbc.jar library, it complains and tell me to use the newer version.
So to get around this, do I have to have the user name only assign to one database and one table?
Thanks a lot for looking into this.
Sai
On Jan 25, 2010, at 4:00 PM, Justin Deoliveira wrote:
Hi Sai,
-Justin
Justin,
spt_fallback_db
spt_fallback_dev
spt_fallback_usg
spt_monitor
spt_values
Sai
Hi Sai,
database, etc...
-Justin
we get an error
Best Regards,
Sai
Justin Deoliveira
Justin Deoliveira
Hi Sai,
I just found this topic related to connection string:
http://old.nabble.com/Connection-to-SQL-Server-2008-Spatial-ts20723119.html#a20773501
best regards
Sarah
Hi Sai,
as?
-Justin
Justin,
spt_fallback_db
spt_fallback_dev
spt_fallback_usg
spt_monitor
spt_values
Sai
Hi Sai,
is
other
database, etc...
-Justin
create
name,
we get an error
table
this
Best Regards,
Sai
the
Conference
through
companies.
Justin Deoliveira
the
Conference
through
companies.
Justin Deoliveira
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the
business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
View this message in context: http://old.nabble.com/SQL-Server-Store-creation-problem-tp27301377p27320715.html
