I'm new to geoserver, but from what I've seen it looks
great! However, I can't get it to load my geotiff file.
I went through the tutorial using sample.tiff and it loaded
fine. When I do those same steps with my own geotiff (whose
gdalinfo is below), I get the error:
Unknown SRS EPSG:UNKNOWN
upon submitting it in the 'Coverage Editor/Edit Coverage
meta-data' page.
There is a .tfw file with the .tiff. Is that data reduntant
to what is in the geotiff header of the file?
Do I need to add more epsg definitions to the
epsg.properties file? There are only 26 lines in that file.
Shouldn't there be lots more?
Can geoserver handle this format? Do I need to use
gdal_translate or something similar to convert this file to
something that geoserver does like?
Thank you,
Wendell
server: geoserver-1.6.4b-bin.zip
os: Fedora 3
PROJCS[" Projection Name = Lambert Conformal Conic Units =
meters GeoTIFF Units = meters",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",38.66667],
PARAMETER["standard_parallel_2",33.33333],
PARAMETER["latitude_of_origin",34],
PARAMETER["central_meridian",-105.5],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
