Hello everybody.
I’m trying to configure a geoserver 2.20.05 server (in the windows platform with jetty web server )
I generated a new keystore, and validated it with keytool, and put it in the %GEOSERVER_HOME%\etc directory.
I validated which version of jetty is installed and the i got in the Central Repository: org/eclipse/jetty/jetty-distribution/9.4.36.v20210114 (maven.org)
some files and
Copy ssl.mod from /modules to %GEOSERVER_HOME%\modules
Copy jetty-ssl-context.xml from /etc to %GEOSERVER_HOME%\etc
whith the comand java -cp jetty-util-9.4.36.v20210114.jar org.eclipse.jetty.util.security.Password password
i obtain the obfuscated password (OBF: ) which I used to change the ssl-context.xml file.
the next step was to change my strat.ini by adding the following text:
#SSL
—module=ssl
jetty.ssl.port=8443
#jetty.ssl.idleTimeout=30000
jetty.sslContext.keyStorePath=etc/keystore
jetty.sslContext.trustStorePath=etc/keystore
jetty.sslContext.keyStorePassword=OBF:1k091 …
jetty.sslContext.keyManagerPassword=jetty.sslContext.keyManagerPassword=OBF:1u2u1wml1z7s1z7a1wnl1u2g
jetty.sslContext.trustStorePassword="OBF:1k0915ke…
Number of acceptors (-1 picks default based on number of cores)
jetty.ssl.acceptors=-1
Number of selectors (-1 picks default based on number of cores)
jetty.ssl.selectors=-1
–module=https
jetty.ssl.port=8443
jetty.httpConfig.securePort=8443
note:
I didn’t put, of course, the obf of my keystore password in this email
when i start the service it dont work, and i got this in teh logs file
2022-09-21 14:29:26.303:INFO::main: Logging initialized @562ms to org.eclipse.jetty.util.log.StdErrLog
2022-09-21 14:29:26.665:WARN:oejx.XmlParser:main: FATAL@…3247… line:35 col:5 : org.xml.sax.SAXParseException; lineNumber: 35; columnNumber: 5; The element type “Configure” must be terminated by the matching end-tag “”.
2022-09-21 14:29:26.665:WARN:oejx.XmlConfiguration:main:
java.security.PrivilegedActionException: org.xml.sax.SAXParseException; lineNumber: 35; columnNumber: 5; The element type “Configure” must be terminated by the matching end-tag “”.
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1857)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:218)
at org.eclipse.jetty.start.Main.start(Main.java:491)
at org.eclipse.jetty.start.Main.main(Main.java:77)
Can i have some help for correct this???
best regards
