I installed Geoserver 2.1 with Apache as web archieve. when i click "add new
store" and click browse button to add a new shapefile, then i got this
strange error:
Oops, something went wrong...
Sorry, something unexpected happened on the server.
Here's an error report you can include in a JIRA bug report about this
issue:
org.apache.wicket.WicketRuntimeException: Exception in rendering component:
[MarkupContainer [Component id = roots]]
at org.apache.wicket.Component.renderComponent(Component.java:2725)
at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1538)
at org.apache.wicket.Component.render(Component.java:2517)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1440)
at
org.apache.wicket.MarkupContainer.renderComponentTagBody(MarkupContainer.java:1603)
at
org.apache.wicket.MarkupContainer.renderAssociatedMarkup(MarkupContainer.java:696)
at
org.apache.wicket.markup.html.panel.Panel.onComponentTagBody(Panel.java:114)
at org.apache.wicket.Component.renderComponent(Component.java:2686)
at
at
at
I could not really understand, why this happen
Please Guide me to fix this error if anybody knows about this
thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Strange-error-by-adding-a-new-resource-tp6414903p6414903.html
strange error:
issue:
Looks like it's the same error as http://jira.codehaus.org/browse/GEOS-4422
Are you on Windows as well?
If so I suggest you try out a nightly build and report back:
http://gridlock.opengeo.org/geoserver/2.1.x/geoserver-2.1.x-latest-bin.zip
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Yes, its same error, and i am using windows web server 2008 R2. From this
link
I got Geoserver's zip file. But as you know, i want geoserver.war file for
using it with Apache tomcate.
Can you send me Geoserver 2.1.x's .war file?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Strange-error-by-adding-a-new-resource-tp6414903p6415279.html
On Sat, May 28, 2011 at 10:52 PM, Mustafa646 <noorcs22@anonymised.com> wrote:
link
Just look in the same directory:
Ing. Andrea Aime
Tech lead
Great!
It works perfect now.
I have one more question to you. my Geoserver is installed at server
192.168.33.123 where as OL web application is hosted at different server
172.30.100.34
when i run my web page from outside of production environment, i noted the
layers does not show over google map. I search and come to know that it will
be solved by using some sort of proxy.Can you please tell me which proxy
should i use and how and where i use it ?
Thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Strange-error-by-adding-a-new-resource-tp6414903p6416256.html
