Andrea-
Andrea Aime wrote:
Andreas, it's not that I don't want to help you, but I really don't
know how... I don't use JBoss, I don't run other apps besides GeoServer,
and moreover, I have really no clue about what is going on...
I understand that, and I appreciate your efforts, thank you! Unfortunately, I also have no clue. Meanwhile I found out that you do not need another application at all. JBoss also seems to behave strange with just Geoserver deployed. This is a stack trace I got a minute ago when I tried to open the Geoserver admin page after starting JBoss, then issuing a wms request, and then opening the JBoss admin page (http://localhost:8080/):
21:44:22,244 ERROR [CoyoteAdapter] An exception or error occurred in the container during the request processing
java.lang.IllegalStateException: Cannot call sendRedirect() after the response has been committed
at org.apache.catalina.connector.Response.sendRedirect(Response.java:1228)
at org.apache.catalina.connector.CoyoteAdapter.postParseRequest(CoyoteAdapter.java:438)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:239)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:580)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
The Geoserver admin page was not loaded, instead I got a blank page.
The only problematic interaction between GeoServer and other apps
in JBoss that I'm aware of is GeoServer programmatically controlling
log4j, and jboss sorely failing to isolate the other apps from
what geoserver is doing (http://jira.codehaus.org/browse/GEOS-1671).
Yet I don't see how playing with logging might interact with the http headers of other apps...
Hm. This is interesting. I now even removed the log4j jar from the geoserver deployment. But nothing changed. Then I replaced the log4j jar of the JBoss distribution with the one from the Geoserver distribution. There was a small change: now, when issueing a WMS request for the first time, the following is logged:
21:51:24,803 INFO [DispatcherServlet] Initializing servlet 'dispatcher'
21:51:24,813 INFO [DispatcherServlet] FrameworkServlet 'dispatcher': initialization started
21:51:24,813 INFO [[/geoserver]] Loading WebApplicationContext for Spring FrameworkServlet 'dispatcher'
21:51:24,814 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from ServletContext resource [/WEB-INF/dispatcher-servlet.xml]
21:51:24,834 INFO [XmlWebApplicationContext] Bean factory for application context [WebApplicationContext for namespace 'dispatcher-servlet']: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [requestDispatcher,filePublisher,urlMapping]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [catalog,serviceFinder,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,validation,validationConfig,validationRegisterar,validationConfigRegisterar,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLayersMapProducerFactory,GeoRSSMapProducerFactory,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,applicationState,applicationStateRegisterar]; root of BeanFactory hierarchy
21:51:24,834 INFO [XmlWebApplicationContext] 3 beans defined in application context [WebApplicationContext for namespace 'dispatcher-servlet']
21:51:24,834 INFO [XmlWebApplicationContext] Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@anonymised.com]
21:51:24,834 INFO [XmlWebApplicationContext] Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com5...]
21:51:24,834 INFO [UiApplicationContextUtils] Unable to locate ThemeSource with name 'themeSource': using default [org.springframework.ui.context.support.DelegatingThemeSource@anonymised.com]
21:51:24,834 INFO [DefaultListableBeanFactory] Pre-instantiating singletons in factory [org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [requestDispatcher,filePublisher,urlMapping]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [catalog,serviceFinder,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,validation,validationConfig,validationRegisterar,validationConfigRegisterar,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLayersMapProducerFactory,GeoRSSMapProducerFactory,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,applicationState,applicationStateRegisterar]; root of BeanFactory hierarchy]
21:51:24,850 INFO [DispatcherServlet] Using context class [org.springframework.web.context.support.XmlWebApplicationContext] for servlet 'dispatcher'
21:51:24,851 INFO [DispatcherServlet] Unable to locate MultipartResolver with name 'multipartResolver': no multipart request handling provided
21:51:24,852 INFO [DispatcherServlet] Unable to locate LocaleResolver with name 'localeResolver': using default [org.springframework.web.servlet.i18n.AcceptHeaderLocaleResolver@anonymised.com]
21:51:24,853 INFO [DispatcherServlet] Unable to locate ThemeResolver with name 'themeResolver': using default [org.springframework.web.servlet.theme.FixedThemeResolver@anonymised.com]
21:51:24,861 INFO [DispatcherServlet] No HandlerAdapters found in servlet 'dispatcher': using default
21:51:24,869 INFO [DispatcherServlet] No ViewResolvers found in servlet 'dispatcher': using default
21:51:24,869 INFO [DispatcherServlet] FrameworkServlet 'dispatcher': initialization completed in 56 ms
21:51:24,869 INFO [DispatcherServlet] Servlet 'dispatcher' configured successfully
This was not logged with the JBoss version of log4j. But the problems persist.
Can you give us more information? How are the headers getting ruined?
What's the extra chars you see, are there extra fields?
This is hard to accomplish, because it happens on a random base. But I was able to catch one. I got the following stack trace when trying to open the Geoserver admin page, after clicking around on some pages also served by the same JBossWeb instance:
22:05:25,736 ERROR [[action]] Servlet.service() for servlet action threw exception
java.lang.IllegalStateException: Cannot forward after response has been committed
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:313)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:301)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.doForward(MultipleDelegatingTilesRequestProcessor.java:372)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processTilesDefinition(MultipleDelegatingTilesRequestProcessor.java:217)
at org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processForwardConfig(MultipleDelegatingTilesRequestProcessor.java:80)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:241)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:179)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:157)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
22:05:25,737 ERROR [[localhost]] Exception Processing ErrorPage[exceptionType=java.lang.Exception, location=/WEB-INF/pages/errors/Exception.jsp]
at org.apache.coyote.Response.reset(Response.java:297)
at org.apache.catalina.connector.Response.reset(Response.java:652)
at org.apache.catalina.connector.Response.reset(Response.java:916)
at org.apache.catalina.core.StandardHostValve.custom(StandardHostValve.java:417)
at org.apache.catalina.core.StandardHostValve.throwable(StandardHostValve.java:271)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
The response from JBossWeb was just a blank page with a "0" as content. Unfortunately, I was never able to catch the headers, because the problems only seem to occur when many requests are issued to the server in a very short time, something I could not simulate with wget, which I used to get the headers.
Another catch was the following page of my other application. The page (including headers!) starts with the following lines:
dc9
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
So obviously, there were no headers sent at all.
Ok, this is all information I was able to gather. I still have no clue, hopefully somebody else has? Could it maybe have to do with clustering? Because this is one of the main differences between Apache Tomcat and JBossWeb.
Andreas.
