[Geoserver-users] Strange Neon Blocks in GWC
Hi All,
I have a problem when my map draws from GWC. On certain scales 1:1000, 1:2000, I get strange neon (Turquoise, Purple, etc) blocks in random spots. this only happens in GWC and not through WMS. What can possibly be causing this? See screenshot.
PS. The layer causing the problem is from an “ImagePyramid Store” with GeoTIFF. It uses the default “raster” style.
Best Regards
Schalk
On Fri, Jul 7, 2017 at 12:45 PM, Schalk Grobbelaar <swgrobbelaar@anonymised.com>
wrote:
Hi All,
PS. The layer causing the problem is from an "ImagePyramid Store" with
GeoTIFF. It uses the default "raster" style.
I don't remember seeing this particular problem, the block shape and
distribution is... perplexing :slight_smile:
So no clue, I'm going to make some more questions to help reduce the
context of the issue.
Does it happen in all caching formats? png vs jpeg in particular
Do you have more installation details, like for example, OS, if you have
imageio native extension installed?
Andrea Aime
GeoServer Professional Services from the experts! Visit GeoSolutions Enterprise Support Services
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
This happens on JPEG as well as PNG, and at random locations. If I reseed it dissapears from original location but again appear in new location. Totally random. We run Geoserver 2.11.0 on Ubuntu 16.04 with imageio native extension installed.
Regards
Schalk
On 2017/07/07 13:51, Andrea Aime wrote:
On Fri, Jul 7, 2017 at 12:45 PM, Schalk Grobbelaar <swgrobbelaar@…84…> wrote:
Hi All,
I don’t remember seeing this particular problem, the block shape and distribution is… perplexing :slight_smile:
So no clue, I’m going to make some more questions to help reduce the context of the issue.
Do you have more installation details, like for example, OS, if you have imageio native extension installed?
Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
On Fri, Jul 7, 2017 at 2:12 PM, Schalk Grobbelaar <swgrobbelaar@anonymised.com>
wrote:
Hi Andrea,
Try removing the native extensions then (they are know to misbehave on
occasion,
and since they were closed source, they cannot be fixed).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
Will try that and will get back to you.
Thanks for the help so far.
Appreciated.
Regards
Schalk
On 2017/07/07 14:17, Andrea Aime wrote:
On Fri, Jul 7, 2017 at 2:12 PM, Schalk Grobbelaar <swgrobbelaar@…84…> wrote:
Hi Andrea,
Try removing the native extensions then (they are know to misbehave on occasion,
Andrea Aime
Regarding:
“Try removing the native extensions.”
A lot of articles on the web regarding how to install Native JAI and Native JAI IOImage, but nowhere I can get instructions of how to remove it from geoserver. Can someone point me in right direction?
Regards
Schalk
Hi Andrea,
Andrea Aime
