Hello,
When I send a style with a WellKnowName of type square to GeoServer with a REST API, the WellKnownName is removed from the SLD definition, because square is the default value.
As a consequence, when I retrieve the SLD with a GET on the REST API and I compare it to my definition, it is detected as a difference.
Shouldn’t the REST API respect the original content sent?
Alexandre Gacon
It has always dropped default values e.g. square marks, black strokes and grey fills etc. It avoids cluttering up the SLD with unnecessary elements. The simplest answer would seem to be for you to leave such defaults out of your SLD files (or ignore them when looking for differences).
Ian
Alexandre Gacon
Ian Turton
Yep, as Ian says, “pretty printing” of the style has been the default since the beginning of the REST API availability.
However, there is a query paameter you can append to your style publication, that allows skipping the pretty print:
“…?raw=true”.
Looks like it’s not documented in the REST API, although it has also been in the API for many years.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Alexandre Gacon
Ian Turton
Thanks Andrea ! I will try it as soon as possible!
Alexandre
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Alexandre Gacon
Ian Turton
