[Geoserver-users] Styling a view with zoom-based style failed
Hi there,
I’m trying to style a Geoserver SQL View, my style doc is something like:
[@sd < 2000000 ] {
mark: symbol(square);
mark-size: 6px;
:mark {
fill: #00cc33;
The problem is that the zoom-based rule “[@sd < 2000000 ]” has no effect, the features appear in all zoom levels. But if I use the same style doc to style a table layer (rather than a SQL view layer) the zoom-based rule works correctly.
What is the problem?
Fawzy
honestly, I have no idea, the scale dependency code has no knowledge of the underlying
data source and is applied before data access even takes place. I would check for other possible causes.
On Sun, Apr 22, 2018 at 1:05 PM, <fawzyb@anonymised.com> wrote:
Hi there,
[@sd < 2000000 ] {
mark-size: 6px;
:mark {
fill: #00cc33;
Fawzy
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com.382…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Only possibility I can think of is that GeoServer thinks the view is in a different projection and hence scale that the table.
Ian
On 22 April 2018 at 17:05, Andrea Aime <andrea.aime@anonymised.com7…> wrote:
Hi there,
[@sd < 2000000 ] {
mark-size: 6px;
:mark {
fill: #00cc33;
Fawzy
Geoserver-users@anonymised.comrge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
Thanks a lot for your reply.
Ian is right, the problem was in the different projection, I have set the correct projection and it works fine.
Thanks again.
Fawzy
On 22 April 2018 at 17:05, Andrea Aime <andrea.aime@anonymised.com…> wrote:
Hi there,
[@sd < 2000000 ] {
mark-size: 6px;
:mark {
fill: #00cc33;
Fawzy
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
