[Geoserver-users] Styling: polygon fill with markers and margins
Hello all,
Question regarding styling: we have polygon layers with marker fills. When using a margin (to add space between markers) it seems the marker is cut apart, with the bottom of the marker appearing at the top. I am attaching an example to hopefully make this clearer (image and SLD file), with one rule without margin (on the left, marker appears correctly) and the other with a margin of 5 (on the right, marker appears to be broken). Is this expected behavior?
Thanks in advance,
Cécile
polygon_marker_fill_margin.sld (3.29 KB)
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Cécile Vuilleumier
Geospatial developer
Camptocamp SA
Route de la Chaux 4
Bâtiment A (Feuille)
1030 Bussigny
Switzerland
+41 62 544 03 77 (direct)
+41 21 619 10 10 (central)
www.camptocamp.com
Hi Cécile,
this does not look like expected behavior to me… the fill is really just a repetition of a
static image that is being built based on the mark, using a 3x3 template to account
for eventual symbol self-overlap (due to antialisasing).
I guess the code is not working well for the triangle case. I cannot help further, but C2C
has plenty of Java developers, if you are one or can contact one, here is the area of code
where I’d start looking:
https://github.com/geotools/geotools/blob/0613fa6cc9f132c3354f68011365a84dcfc5f707/modules/library/render/src/main/java/org/geotools/renderer/style/SLDStyleFactory.java#L1164
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
