[Geoserver-users] Styling Sld using strReplace to ignore accented characters
Hello all,
I need some help with the regex of the function “strReplace” because according to the docs http://docs.geoserver.org/stable/en/user/filter/function_reference.html i can use any regular expression from java, but when i use the expression “\p{IsM}+” is not working as on java, i made the tests using the same version of java runtime JDK7.
The example string: “ábÈitõ”
Pattern: \p{IsM}+
Replace: “”
Java response: “abEito”
But the geoserver Response still having the accents.
<ogc:Function name=“strReplace”>
ogc:PropertyNamePROPERTY_NAME</ogc:PropertyName>
ogc:Literal\p{IsM}+</ogc:Literal>
ogc:Literal/
ogc:Literaltrue</ogc:Literal>
</ogc:Function>
Thanks.
On Wed, Feb 11, 2015 at 9:47 PM, Danilo da Silveira Figueira <
danilomalzao@anonymised.com> wrote:
Hello all,
I need some help with the regex of the function "strReplace" because
"\p{IsM}+" is not working as on java, i made the tests using the same
The example string: "ábÈitõ"
Pattern: \p{IsM}+
Replace: ""
Java response: "abEito"
<ogc:Function name="strReplace">
<ogc:PropertyName>PROPERTY_NAME</ogc:PropertyName>
<ogc:Literal>\p{IsM}+</ogc:Literal>
<ogc:Literal/>
<ogc:Literal>true</ogc:Literal>
</ogc:Function>
Hum... I don't know, the code definitely uses java regular expressions:
https://github.com/geotools/geotools/blob/master/modules/library/main/src/main/java/org/geotools/filter/function/FilterFunction_strReplace.java
which uses in turn:
https://github.com/geotools/geotools/blob/master/modules/library/main/src/main/java/org/geotools/filter/function/StaticGeometry.java#L553
It may well be that your non ASCII chars get lost travelling from the db to
this expession?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea thanks for your reply,
Well i am using files instead of DB but i guess that the enconding problem can be the same, i dont have any clue about how to solve this.
My guesses, if it is a enconding problem, there is a tool that can automatically correct the *.idb files to utf-8, or can i specify a encondig to sld files use for interpreting the records?
Ps: In case someone is interested the server address csr.ufmg.br/maps
2015-02-12 4:58 GMT-02:00 Andrea Aime <andrea.aime@anonymised.com>:
On Wed, Feb 11, 2015 at 9:47 PM, Danilo da Silveira Figueira <danilomalzao@anonymised.com> wrote:
Hello all,
Pattern: \p{IsM}+
Replace: “”
ogc:Literal/
</ogc:Function>
Hum… I don’t know, the code definitely uses java regular expressions:
which uses in turn:
It may well be that your non ASCII chars get lost travelling from the db to this expession?
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Feb 12, 2015 at 3:19 PM, Danilo da Silveira Figueira <
What's an idb file?
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry, i mean to change the Shapefile encondig to utf-8.
What i said about idb, is because the string names of the shapefile usually are contained in a “idb” file.
att
2015-02-12 12:27 GMT-02:00 Andrea Aime <andrea.aime@anonymised.com>:
On Thu, Feb 12, 2015 at 3:19 PM, Danilo da Silveira Figueira <danilomalzao@anonymised.com> wrote:
What’s an idb file?
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
i have tried changing the encoding of the server but it does not solved the problem, i guess that the problem is really in geoserver.
att
2015-02-12 11:32 GMT-03:00 Danilo da Silveira Figueira <danilomalzao@anonymised.com>:
att
2015-02-12 12:27 GMT-02:00 Andrea Aime <andrea.aime@…1107…>:
What’s an idb file?
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Feb 12, 2015 at 3:32 PM, Danilo da Silveira Figueira <
If the dbf file is really in utf8, have you tried changing the charset in
the data store config dialog?
There should be a drop down there if memory serves me right (I don't have a
geoserver handy right now)
Ing. Andrea Aime
@geowolf
Technical Lead
Well, after changing the storage encondig the strings are showed correctly in the WMS respose but the records yet still having accents. =/
2015-02-12 12:54 GMT-03:00 Andrea Aime <andrea.aime@anonymised.com7…>:
On Thu, Feb 12, 2015 at 3:32 PM, Danilo da Silveira Figueira <danilomalzao@anonymised.com> wrote:
If the dbf file is really in utf8, have you tried changing the charset in the data store config dialog?
There should be a drop down there if memory serves me right (I don’t have a geoserver handy right now)
Ing. Andrea Aime
@geowolf
Technical Lead
It fails even when i try something like this:
áéíÀÈ`RÌ \p{IsM}+ a true
2015-02-12 13:32 GMT-03:00 Danilo da Silveira Figueira <danilomalzao@anonymised.com>:
2015-02-12 12:54 GMT-03:00 Andrea Aime <andrea.aime@anonymised.com>:
Ing. Andrea Aime
@geowolf
Technical Lead
