[Geoserver-users] Styling the Admin page of a server
Hi List,
I have two different sets of GeoServer instances which are doing different things. The problem is they all have admin pages that look identical. The only difference is a single digit in the URL bar for which port they’re coming from. And a different digit difference for if they’re on a different server (live/test).
I haven’t yet managed to set something on the wrong server, but it’s only a matter of time.
Is there an easy way to restyle the GeoServer admin interface? I’m not looking for anything fancy; even just the ability to recolour the background would be useful (a very light shade of a colour would allow instant differentiation between servers - works wonderfully work remote desktops).
And/Or maybe the server name in big letters at the top?
How do other people handle this issue?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Jonathan,
Hi Jonathan,
yes, pain in the butt this, noticing suddenly -- ooops I am fiddling around
with the production server not the test server as I thought.
web-core-2.3.3.jar
directory org/geoserver/web/img
a good candidate is: page-header-bg.png, which is now pink. Another would be
http://lctest.land.vic.gov.au/cm/test_instance.gif
I rather doubt the community would approve of this pink, but it helps me to
distinguish.
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department of Sustainability and Environment
Level13, Marland House, 570 Bourke Street
Melbourne 3000
PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.x6.nabble.com/Styling-the-Admin-page-of-a-server-tp5069841p5071652.html
Hi Christian,
Somehow I’d never realised the jars could be uncompressed. I can be a bit slow. :slight_smile:
However, you’re right that does allow one potential solution. With a little tweaking there’s one that I think is even easier than yours (no image manipulation required), plus has a more noticeable effect. Basically editing the css colour for the header - I’ve opened a JIRA suggesting it as an improvement which details the file and line - http://jira.codehaus.org/browse/GEOS-5964
Some examples:
https://docs.google.com/file/d/0B22cYd3gwE-6WjlISXBmREFHb1U
https://docs.google.com/file/d/0B22cYd3gwE-6ZWlHRmdTZ2VjOUk
https://docs.google.com/file/d/0B22cYd3gwE-6d1hGaUFLOWFzS0E
The downside of course is that like yours, it has to be re-implemented every upgrade (which we’re doing monthly currently). Hence the suggestion.
Thanks!
Jonathan
On 9 August 2013 00:46, cmaul <Christian.Maul@anonymised.com> wrote:
Hi Jonathan,
Hi Jonathan,
yes, pain in the butt this, noticing suddenly – ooops I am fiddling around
web-core-2.3.3.jar
distinguish.
Christian
Dr Christian Maul
Project Manager
Melbourne 3000
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It’s a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-users mailing list
