[Geoserver-users] symbol disappear in geoserver 2.3.2
hi all …
I have problem to show symbol in preview at geoserver 2.3.2.
When in geoserver 2.3.0, the symbol appear in preview.
The symbol I use is in png format. I enter in C:\Program Files\GeoServer 2.3.2\data_dir\styles with the size is less then 10 KB.
In geoserver 2.3.0, the symbol appear normally. But, in geoserver 2.3.2, the symbol disappear.
I have minimized the size of pixel so the size is same with grass_fill.png which grass_fill.png is made by geoserver.
The size of pixel is 32 x 32.
I have treated the same as grass_fill.png in resolution. The resolution is 72 dpi.
I use windows7.
Could anyone explaining why the symbol disappear in 2.3.2 ?
thanks for help
On Tue, Jun 4, 2013 at 8:36 AM, mega saputra <megasaputra9@anonymised.com> wrote:
hi all ...
72 dpi.
I use windows7.
No idea. Can you share the SLD and the symbol you're using on this mailing
list?
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I have changed graphic symbol by grass_fill.png. It’s work. But, when I change to my graphic symbol. It doesn’t work.
Is there any other criteria to make png symbol, so that the symbol will appear? Cause I have adjusted the resolution and size of pixel, so that same with grass_fill.png.
I share my sld and png.
In GeoServer 2.3.0, I don’t adjust the resolution and size of pixel. But, it is work. I only make the size is less then 10 kb. But, in 2.3.2, it is not work.
The color symbol is work. Only the graphic symbol that doesn’t work.
Thank you for your help.
sld and png.zip (31.4 KB)
On Wed, Jun 5, 2013 at 8:09 AM, mega saputra <megasaputra9@anonymised.com> wrote:
I share my sld, shp, and png.
On Tue, Jun 4, 2013 at 3:38 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
hi all …
I use windows7.
No idea. Can you share the SLD and the symbol you’re using on this mailing list?
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
