[Geoserver-users] TextSymbolizer without a Label
I have a feature with the attached style. I don’t see any problems until I try to export the feature to google earth. Then I see the following errors in geoserver. I debugged the issue and it turns out I don’t have a Label tag under the TextSymbolizer element in the SLD. The documentation states the Label element isn’t required. Is that not the case in google earth?
From the code:
org.geoserver.kml.decorator.PlacemarkNameDecoratorFactory.java:64 calls
org.geotools.styling.SLD line 1171 which returns a null:
Symbolizer = null
From the logs:
22:28:57,754 ERROR [org.geoserver.ows] (http-/0.0.0.0:8443-6) : java.lang.NullPointerException
at org.geoserver.kml.decorator.PlacemarkNameDecoratorFactory$PlacemarkNameDecorator.decorate(PlacemarkNameDecoratorFactory.java:64) [gs-kml-2.7.2.jar:2.7.2]
at org.geoserver.kml.sequence.FeatureSequenceFactory$FeatureGenerator.next(FeatureSequenceFactory.java:121) [gs-kml-2.7.2.jar:2.7.2]
at org.geoserver.kml.sequence.FeatureSequenceFactory$FeatureGenerator.next(FeatureSequenceFactory.java:80) [gs-kml-2.7.2.jar:2.7.2]
at org.geoserver.kml.sequence.SequenceList$GeneratorIterator.(SequenceList.java:29) [gs-kml-2.7.2.jar:2.7.2]
at org.geoserver.kml.sequence.SequenceList.iterator(SequenceList.java:63) [gs-kml-2.7.2.jar:2.7.2]
geoserver url from google earth:
http://localhost/geoserver/wms?crs=CRS:84&time=2015-12-24T00:00:00.000Z&height=1024&bbox=-163.2354539790473,15.57941628804031,-147.6617927872543,27.65836991454673&layers=tracks:pimTrack-indicator5&width=1024&request=GetMap&service=WMS&styles=&format_options=SUPEROVERLAY:false;KMPLACEMARK:false;KMSCORE:40;KMATTR:true;&format=application/vnd.google-earth.kmz&transparent=false&version=1.3.0
Dominique Bessette
gis_pim_posit.sld (7.3 KB)
On Wed, Dec 23, 2015 at 12:00 AM, Bessette-Halsema, Dominique E <
This is a surprise to me, but checking the SLD schema, you are right, the
Label element is indeed optional.
I think you already answered yourself, no? :slight_smile:
From the code:
Symbolizer = <TextSymbolizerImp property=posit_geom label=null>null
From the logs:
        at
        at
        at
        at
org.geoserver.kml.sequence.SequenceList$GeneratorIterator.<init>(SequenceList.java:29)
        at
Yep, makes sense, the code is not accounting for a missing label element,
only for an empty one.
Feel free to submit a bug report here:
https://osgeo-org.atlassian.net/projects/GEOS/summary
If you have programming skills a pull request fixing this, with a test,
against the master branch, would be much appreciated:
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
This leaves the question of what you expected the output to be in this case? The spec says:
"The Label element is used to provide text-label content. It is defined as follows:
<xs:element name=“Label” type=“sld:ParameterValueType”/
The ParameterValueType may refer to a complex value and the type of the
property/expression is unimportant as the system is expected to provide a text-string
version of the property/expression for rendering whatever its type. If a Label element is
not provided in a TextSymbol , then no text will be rendered." (My emphasis)
so that symbolizer will do nothing and can be deleted as a simple workaround.
Ian
On 23 December 2015 at 07:30, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-users mailing list
On Wed, Dec 23, 2015 at 12:00 AM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
This is a surprise to me, but checking the SLD schema, you are right, the Label element is indeed optional.
From the code:
Symbolizer = null
From the logs:
Yep, makes sense, the code is not accounting for a missing label element, only for an empty one.
Feel free to submit a bug report here: https://osgeo-org.atlassian.net/projects/GEOS/summary
If you have programming skills a pull request fixing this, with a test, against the master branch, would be much appreciated:
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
