[Geoserver-users] The requested URL /geoserver/web was not found on this server
Installed Geoserver 2.4.1 on Windows 7. Getting above error, please help.
I know the error is too generic and problem could be anything , attaching
LOG file for your reference.
New to GeoServer ... Your help appreciated geoserver.log
<http://osgeo-org.1560.x6.nabble.com/file/n5095087/geoserver.log&gt; ! :slight_smile:
View this message in context: http://osgeo-org.1560.x6.nabble.com/The-requested-URL-geoserver-web-was-not-found-on-this-server-tp5095087.html
The scratchDir you specified: C:\Windows\system32\........... is unusable.
Looks rather simple; You are not allowed to create or write into this
directory.
Quick check: Please start Geoserver as an administrator. I suspect it would
work.
Please note: There is a difference in Windows7/8 of BEING an administrator
and RUNNING a program as an administrator.
My general recommendation would be: Do not deploy in the 'Program Files ' or
P...(x86)' directory, pull the data directory out of the program and put it
somewhere else without write protection, avoid the use of user or system
directories for anything (logging, properties etc.) as they are
write-protected as well.
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department Environment and Primary Industries
Level13, Marland House, 570 Bourke Street
Melbourne 3000
PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.x6.nabble.com/The-requested-URL-geoserver-web-was-not-found-on-this-server-tp5095087p5095178.html
Thanks cmaul !
It worked.
View this message in context: http://osgeo-org.1560.x6.nabble.com/The-requested-URL-geoserver-web-was-not-found-on-this-server-tp5095087p5095238.html
