[Geoserver-users] Tiff image
Hi Guys ,
I have to show Tiff Images to the users embeddd in the map how can i do it using geoserver.
Vijay Akkineni.
Online or offline (as a static image)?
Alex
On 2/20/06, Akkineni Vijay <akkineniv@...84...> wrote:
Hi Guys ,
Vijay Akkineni.
You can download a pre-compiled release, or checkout the SVN version
(which is what I use):
https://svn.codehaus.org/geoserver/branches/wcs-branch
Maybe someone on the list will know what this error means, I am afraid
I don't know a soultion for this particular error right away.
Let me know if you need any other pointers with regards to the WCS release.
Alex
On 2/21/06, Akkineni Vijay <akkineniv@...84...> wrote:
Hi Alex
                Thanks very much for the info . I need to produce exactly a
simillar map as given in the link below . But when i installed the
geoserver stable version of 1.3.0 . it had only wfs and wms capabillites ,
Then i installed geoserver-1.3.0-RC2-WCS-war.zip for wcs capabillites but i
was reciveing error like "missing key text.visitdemopage" , I have added
the key to the application properties file even then i still recieve the
error . can u tell me which is the latest version i should download so that
i wont recive these error and have wcs capabillites.
Thanks and Regards,
Vijay Akkineni.
On 2/21/06, Alexander Petkov <greenkov@...84...> wrote:
> You need to use the WCS branch of Geoserver and configure your images
> as "World Image" coverages.
> Do you need to produce something like this:
> http://docs.codehaus.org/display/GEOSDOC/Gallery
> Alex
> On 2/20/06, Akkineni Vijay < akkineniv@...84...> wrote:
> > Hi Alex,
> > to show the images Online ..
> > Vijay
> > > Alex
> > > On 2/20/06, Akkineni Vijay < akkineniv@...84... > wrote:
> > > > Hi Guys ,
in
> > the
> > > > Regards,
> > > > Vijay Akkineni.
as Alexander suggested, you need to use the coverage branch you can find here
http://docs.codehaus.org/display/GEOS/Experimental
I would suggest you to keep an eye on the Experimental web page since
a new version of the above mentioned branch will be released very soon
(we are targeting half of March as a deadline) with several
improvements.
Ciao, Simone.
On 2/20/06, Akkineni Vijay <akkineniv@anonymised.com> wrote:
Hi Guys ,
Vijay Akkineni.
Simone Giannecchini
Software Engineer
Freelance Consultant
http://simboss.wordpress.com/
