Hello,
I have a large TIFF file made with the following command:
gdal_translate.exe source.ecw d:\gdalcogtif.tif -of COG -co COMPRESS=WEBP -co BIGTIFF=YES -co NUM_THREADS=7
This works fine in QGIS, and I’m able to add the layer to GeoServer. When rendering however, I get these errors in the console:
javax.imageio.IIOException: Unsupported compression type (tag number = 50001)!
at it.geosolutions.imageioimpl.plugins.tiff.TIFFImageReader.read(TIFFImageReader.java:1939)
at com.sun.media.jai.imageioimpl.ImageReadOpImage.computeTile(ImageReadOpImage.java:697)
I’d prefer to keep the file that’s provided, and not adding another layer of transformation. Would it be possible to add WEBP decompression for the Image IO library?
Jelmer Baas
Hi Jelmer,
in theory yes, but does not seem trivial.
Searching for Java support for webp returns projects that are discontinued or even removed from repositories (like the Luciad one).
The webp library itself seems to have java bindings, but they are not deployed in the Maven repositories it sees, so one has
to build everything from source.
Assuming one can get a encoder/decoder for webp bound to Java, then changes to these libraries should be made,
creating a new TIFFWebPCompressor/Decompressor, and supporting the same TIFF tags that GDAL is using for it in the TIFFImageReader:
https://github.com/geosolutions-it/imageio-ext/tree/master/plugin/tiff/src/main/java/it/geosolutions/imageioimpl/plugins/tiff
Overall, does not seem trivial, but possibly doable.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
Thanks for the reply. I’m currently still not that well versed in the Java world, so I’m afraid this experiment will have to wait. Who knows, one day…
Jelmer Baas
Sent: maandag 1 maart 2021 18:10
To: Jelmer Baas <jelmerbaas@…10668…>
Subject: Re: [Geoserver-users] TIFF with WEBP compression
Hi Jelmer,
On Mon, Mar 1, 2021 at 4:17 PM Jelmer Baas <jelmerbaas@…10668…> wrote:
Hello,
Jelmer Baas
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
