Keep in mind that use tiles allows for reuse of generated tiles, either with server-side tile caches or client side image caching (In you Layer, turn on "Response Cache Headers" and set a value (seconds) under the Layer "Publishing" tab).
Tiling has benefits if you anticipate a lot of panning (only loads new tiles on leading edge of panning, even without caching). If tile rendering is expensive caching allows for tiles to be requested and/or generated once (NOTE: be careful if the underlying datastore is not static). With a single tile the entire image bust be re-rendered and transmitted on every map movement (little hope of caching/reuse unless navigation is restricted)
As Jonathan stated proper use depends on the client application and backing data. I like to use a combination of integrated WMS tile caches with HTTP Response Headers enabling browser caching. For use of integrated WMS tile caches your OpenLayers Map and WMS layer (client and server side) need to setup correctly have this work properly (&tiled=true, appropriate tie point and zoom levels, published WMS layer styles, etc). Depending on your workflow the effort can be worth the hassle as it will allow for very responsive application.
Tom Kunicki
Center for Integrated Data Analytics
U.S. Geological Survey
8505 Research Way
Middleton, WI 53562
On May 7, 2013, at 3:16 PM, Victor Eriksen <victor.m.eriksen@anonymised.com> wrote:
Thanks for the reply Jonathan!
Tiling the basemaps and using singletile for overlays will probably be the best choice in this case, Dozens and dozens of tiles do get requested, slowing down for the end user as you say.
Victor
2013/5/7 Jonathan Moules <jonathanmoules@anonymised.com>
Hi Victor,
From my limited experience, I don't think there's a "right" answer. Myself I only have tiled the base-maps. Our other layers are served directly from the database.
I guess if there are one or two layers that will be on lots more than most, it may be worth tiling.
The issue with lots of tiles is - the browser can only request a few images at a time (6-8 concurrent connections per server sort of thing). So if you have dozens and dozens of tiles, things will be going very slowly for the end user.
Others may have different opinions/experiences.
Jonathan
On 7 May 2013 12:45, Victor Eriksen <victor.m.eriksen@anonymised.com> wrote:
Hi!
I'm trying to figure out the best tiling strategy for overlays. I have a client where the user can access and view many overlays simultaneously from GeoServer. My present strategy is that all overlays are requested as tiled, some using the cache from GeoWebcache. However it seems as GeoServer is somewhat clogged when too many overlays are read at the same time. I guess accessing overlays as tiled generates a lot of requests (in comparison with singletile) and thus could clog down GeoServer?
My question is, would it be a better strategy to request overlays as singletile in the situation when many overlays are used at the same time?
Victor
Learn Graph Databases - Download FREE O'Reilly Book
"Graph Databases" is the definitive new guide to graph databases and
their applications. This 200-page book is written by three acclaimed
leaders in the field. The early access version is available now.
Download your free book today! http://p.sf.net/sfu/neotech_d2d_may
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Download your free book today! http://p.sf.net/sfu/neotech_d2d_may_______________________________________________
