I have Geoserver version 2.24.2 running under Tomcat 9.0.85. Tomcat displays this error message:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.geoserver.web.admin.StatusPanel (file:/srv/tomcat/webapps/geoserver/WEB-INF/lib/gs-web-core-2.24.2.jar) to method sun.java2d.pipe.RenderingEngine.getInstance()
WARNING: Please consider reporting this to the maintainers of org.geoserver.web.admin.StatusPanel
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Do I need to worry about this?
Georg
Hi Georg,
it’s GeoServer trying to figure out which rasterizer is used by the JVM, some as faster than
others. It’s normal behavior.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
