[Geoserver-users] Tooltips in the map.
Hello all,
I would like to ask some suggestions about the best way to do the following:
I have three layers
a) points
b) polygons
c) lines
I would like to show information about them in tooltips in the map. The information will be retrieved from PostGIS.
How the points, polygons and lines cab be individualized in the layer?
The layers are generated like.
new ol.layer.Image({
source: new ol.source.ImageWMS({
url: ‘http://192.168.1.113:8080/geoserver/wms’,
params: {‘LAYERS’: ‘watermains’},
projection: projection,
serverType: ‘geoserver’
Points in the layer are a single feature, but I need to identify each point (polygons, lines) in order to show the information about each one.
I notice that Geoserver shows the feature type details in the Edit Layer page. Do you think that this information can help me in any way?
I’ve been checking Freemarker to get the info from PosGIS but this won’t help unless I am able to match point (polygons, lines) with their location in the layer.
Any help will be very much appreciated.
Thanks.
JJ.
Jair,
I might not be understanding your question exactly, but are you trying to just get details back about point, polygon, and lines at a particular location in your GeoServer hosted map? If so and you are using WMS, then you can just have your client application issue a WMS GetFeatureInfo request, which will return all of the attributes of the features at that location.
See http://docs.geoserver.org/stable/en/user/services/wms/reference.html#getfeatureinfo
I hope I have understood your question correctly.
  • Mike Grogan
On Wed, Aug 12, 2015 at 8:54 PM, Jair Santos <jsantos5954@anonymised.com> wrote:
Hello all,
I have three layers
a) points
b) polygons
c) lines
Thanks.
JJ.
Geoserver-users mailing list
Thank you Mike.
Yes, I guess that this is what I need. I’ll try it.
Regards.
JJ.
From: Mike Grogan [mailto:d.michael.grogan@anonymised.com]
Sent: Wednesday, August 12, 2015 7:39 PM
To: Jair Santos jsantos5954@anonymised.com
Cc: GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Tooltips in the map.
Jair,
  • Mike Grogan
Hello all,
I have three layers
a) points
b) polygons
c) lines
Thanks.
JJ.
Geoserver-users@anonymised.comourceforge.net
