[Geoserver-users] TopLeftCorner of WMTS GetCapabilities
Hello
I am trying to develop a little viewer with ArcGIS API 4.x and load a basemap from GeoWebCache with WMTS Rest Protocols.
I succeeded in visualizing the basemap with 3857 web mercator and 4326 wgs84 projections.
But I have some difficulties visualizing the basemap with the Lambert 93 (2154) projection.
I then had a closer look at the GetCapabilities of the WMTS.
First I saw that the TopLeftCorner of the TileMatrixSet is not the same over all the levels.
How to obtain something consistent with the same Y for each level ?
Because I didn’t find the capacity to handle this with the arcgis API. (I will ask then to add such ability)
Another remarks Is about the TopLeftCorner of the tileMatrixSet 4326 and tileMatrixSet:2154
The topLeftCorner for EPSG4326 is always 90 -180 but> it seems to be Y X , It should have been -180 90 (X Y)
And for the tileMatrixSet:2154
TopLeftCorner -357823 7289353 seems to be X, Y
Could it be an issue ?
Best regards
Xavier Lhomme
