[Geoserver-users] Translation workflow improvement
About dropping Java 8 support, I do not have an idea when it might happen. It has an connection to Java 17 and I can see this comment in https://github.com/geoserver/geoserver/pull/5248:
“It might be necessary to make a decision if we should keep Java 8 compatibility.”
-Jukka Rahkonen-
Lähettäjä: Alexandre Gacon <alexandre.gacon@…84…>
Lähetetty: keskiviikko 10. marraskuuta 2021 11.55
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@…6847…>
Kopio: Jody Garnett <jody.garnett@…84…>; geoserver-users geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Translation workflow improvement
Thank you Jukka for this test. I think it will need some configuration change on the Transifex side when it will be changed.
Do we have any idea when the support of Java 8 would be dropped in the project?
Regards
Alexandre
Le mer. 10 nov. 2021 à 09:33, Rahkonen Jukka (MML) <jukka.rahkonen@…6847…> a écrit :
Edgar Soldin from the OpenJUMP project is going to change the whole repository into UTF-8, even the properties files https://sourceforge.net/p/jump-pilot/mailman/message/37382192/. He is confident that it can be done also for Java 8 by adding a custom ResourceBundle.Control to I18N as described in https://stackoverflow.com/a/4660195/1308810.
I made a few quick tests which seem to proof that Java 11 can use UTF-8 out-of-the box while the Unicode escapes work for all Java versions. Unicode escapes are manageable in Finnish translations because only 6 characters require escaping but in some other languages almost all characters must be escaped. Being able to use UTF-8 and normal text editors would be nice. Perhaps change could happen at least when Geoserver drops support for Java 8.
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…84…>
Lähetetty: maanantai 8. marraskuuta 2021 19.28
Vastaanottaja: Alexandre Gacon <alexandre.gacon@…84…>
Kopio: geoserver-users <geoserver-users@lists.sourceforge.net>
I am going to have some availability mid week, would love to see this go ahead. I have confirmed admin permission for GeoServer (which has GeoServer, GeoServer Stable, GeoServerTestGitHub, GeoServer 2.1.x, GeoServer 2.2.x).
I am also comfortable with our build system if we can set up a maven or ant scripts to manage translations.
Jody Garnett
On Mon, 8 Nov 2021 at 00:14, Alexandre Gacon <alexandre.gacon@…84…> wrote:
Le dim. 7 nov. 2021 à 17:36, Andrea Aime <andrea.aime@…10949…> a écrit :
On Sun, Nov 7, 2021 at 11:09 AM Alexandre Gacon <alexandre.gacon@…84…> wrote:
Hi Mats,
For the moment it is more a POC than a working system : it needs to be plugged to the geoserver repo instead of my fork.
Right. What about the transifex project you created? Will it be the new reference for translation?
Is there any way to communicate that to the existing translators?
To be discussed with Frank Gasdorf, I think that a brand new project will be better, since the setup can take some time. Transifex has several way to notify people of changes in the project.
I assume that the old project does not have a structure allowing for automation, or there is an access right issue?
The main issue is what will happen to the existing Transifex translation when we plug GitHub integration for a language already translated in GitHub.
I need someone with enough rights to setup this with the official repo.
The links between github resources and transifex resources must be configured by the administrator of the project.
I think Jody offered to help in another thread, but if needs be, I can also set up the integration (just trying to
avoid taking on more stuff, the bits of GeoServer that I cannot delegate to others are already killing me).
I will be happy to work with Jody : it will only require some configuration on the GitHub side.
Alexandre
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Alexandre Gacon
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Alexandre Gacon
