[Geoserver-users] Troubleshooting NETCDF Z index load errors
I am attempting to expose a layer (height) from this netcdf file : http://54.183.9.182/wrf.nc that has a Z index as well as a time dimension. I am able to load and view this layer in the netcdf tools UI grid viewer, but when I attempt to expose it in GeoServer, I get an exception. Any advice on resolving this would be greatly appreciated. Thanks in advance.
The stack trace is :
Caused by: java.io.IOException
at org.geotools.coverage.io.catalog.CoverageSlicesCatalog.getGranules(CoverageSlicesCatalog.java:442)
at org.geotools.imageio.GeoSpatialImageReader.getImageIndex(GeoSpatialImageReader.java:151)
at org.geotools.coverage.io.netcdf.NetCDFResponse.processRequest(NetCDFResponse.java:252)
at org.geotools.coverage.io.netcdf.NetCDFResponse.createResponse(NetCDFResponse.java:146)
at org.geotools.coverage.io.netcdf.NetCDFSource.read(NetCDFSource.java:65)
at org.geotools.coverage.io.netcdf.NetCDFReader.read(NetCDFReader.java:486)
at org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:143)
at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:974)
at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:855)
at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:346)
… 98 more
Caused by: java.lang.NullPointerException
at org.geotools.coverage.io.catalog.CoverageSlicesCatalog.getGranules(CoverageSlicesCatalog.java:433)
Steve Ferguson
Hi Steve,
do you have any chance to open a JIRA and attach the sample (or a reference if that source isn’t temporary) to the JIRA?
I did a quick check of your sample data and I think I have found the issue.
I would like to investigate and solve it in the next days.
Best Regards,
Daniele
On Fri, Nov 6, 2015 at 8:50 PM, Ferguson, Steve -FS <sferguson@anonymised.com..> wrote:
… 98 more
Steve Ferguson
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
I’ve created Jira issue GEOS-7307. Thanks for your help!
Hi Steve,
Best Regards,
Daniele
… 98 more
Steve Ferguson
