could you please provide us the full stack trace?
On Mon, Jul 25, 2011 at 2:43 PM, Gis Mage <gismage@anonymised.com> wrote:
I’ve tried with 8-bit. Still no luck.
For test reasons, I’ve created a folder and gdal_translate 'd just two tiff files there.
gdalinfo says:
gdalinfo ASTGTM_N42E133_hsh8.tif
Driver: GTiff/GeoTIFF
Files: ASTGTM_N42E133_hsh8.tif
Size is 3601, 3601
Coordinate System is:
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
Origin = (132.999861111111102,43.000138888888905)
Pixel Size = (0.000277777777778,-0.000277777777778)
Metadata:
TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.10.1.9.1.9.2.11 $ $Date: 2004/09/15 18:42:01EDT $
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 132.9998611, 43.0001389) (132d59’59.50"E, 43d 0’ 0.50"N)
Lower Left ( 132.9998611, 41.9998611) (132d59’59.50"E, 41d59’59.50"N)
Upper Right ( 134.0001389, 43.0001389) (134d 0’ 0.50"E, 43d 0’ 0.50"N)
Lower Right ( 134.0001389, 41.9998611) (134d 0’ 0.50"E, 41d59’59.50"N)
Center ( 133.5000000, 42.5000000) (133d30’ 0.00"E, 42d30’ 0.00"N)
Band 1 Block=3601x2 Type=Byte, ColorInterp=Gray
When trying to add a mosaic store, I still get the same error (Unable to acquire a reader for this coverage with format: ImageMosaic).
Tiff files are here:
http://dl.dropbox.com/u/7488735/ASTGTM_N42E132_hsh8.tif
http://dl.dropbox.com/u/7488735/ASTGTM_N42E133_hsh8.tif
Still nothing in the GS log.
The line in gdalinfo: Pixel Size = (0.000277777777778,-0.000277777777778)
caught my attention.
Maybe there is a problem with negative pixel size value?
Negative value is fine since a raster image has its origin on the top and have increasing y coordinates moving to the bottom whilst geographic y coordinates increase in the opposite direction.
Please, let us know.
Daniele
2011/7/22 Gis Mage <gismage@anonymised.com>
Checked, GS is able to load one of theese files alone as a geotiff.
Preview in OL looks ok.
The folder is writeable.
I’ve done a chmod 777 to be sure completely:)
I’ve tried adding the initial aster tiff’s - same error occurs.
So I think I’ll try a gdal_translate to 8-bit, and tell you, if that’ll work.
Thanks for the tip.
2011/7/22 Andrea Aime <andrea.aime@anonymised.com>
On Fri, Jul 22, 2011 at 1:29 PM, Gis Mage <gismage@anonymised.com> wrote:
Hi, Andrea!
Sure, gdalinfo says:
gdalinfo ASTGTM_N39E126_hsh.tif
Files: ASTGTM_N39E126_hsh.tif
Size is 3601, 3601
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Origin = (125.999861111111116,40.000138888888877)
Metadata:
18:42:01EDT $
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 125.9998611, 40.0001389) (125d59’59.50"E, 40d 0’ 0.50"N)
Lower Left ( 125.9998611, 38.9998611) (125d59’59.50"E, 38d59’59.50"N)
Upper Right ( 127.0001389, 40.0001389) (127d 0’ 0.50"E, 40d 0’ 0.50"N)
Lower Right ( 127.0001389, 38.9998611) (127d 0’ 0.50"E, 38d59’59.50"N)
Center ( 126.5000000, 39.5000000) (126d30’ 0.00"E, 39d30’ 0.00"N)
Band 1 Block=64x64 Type=Int16, ColorInterp=Gray
The files actually are hillshades, that I’ve created from ASTER DEM tiffs
using ArcGIS.
Hum… int16, not sure I played with images with that structure.
Is GS able to load one of them alone, as a geotiff?
Besides that, is the directory writable?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Storage Efficiency Calculator
This modeling tool is based on patent-pending intellectual property that
has been used successfully in hundreds of IBM storage optimization engage-
ments, worldwide. Store less, Store more with what you own, Move data to
the right place. Try It Now! http://www.accelacomm.com/jaw/sfnl/114/51427378/
Geoserver-users mailing list
Ing. Daniele Romagnoli
Software Engineer
http://it.linkedin.com/in/danieleromagnoli
