It is from another WMS that is open and doesn’t need credentials.
it looks like the printing system is trying to access a secured resource, and it cannot do that because it’s not authorized to do so
by a security subsystem.
Are you trying to print a layer served from the same GeoServer, or another WMS?
I’m wondering if the print subsystem can pass on the user credentials when making requests, it may be that’s not the case… but
I don’t know how it works well enough. Mauro (cc’ed), do you have any clue?
Regards
On Fri, Dec 9, 2016 at 3:17 PM, Obrecht, Joshua D [DSN] <jobrecht@…662…> wrote:
Below are the entries in the log file. I don’t get any message that pops up. The pdf is created with a footnote that contains the second entry from the log file. Could this be a permissions issue? Is there a way to pass user name and password with the call?
2016-12-09 08:11:53,971 ERROR [print.PDFUtils] - Server returned an error for https://xxxxx/wms?BBOX=93.59662362617522%2C-42.08234015699224%2C93.6671763738248%2C-41.97925984300776&HEIGHT=2375&WIDTH=1626&map_resolution=190&VERSION=1.1.1&FORMAT=image%2Fjpeg&SERVICE=WMS&format_options=dpi%3A190&LAYERS= iowasections&REQUEST=GetMap&STYLES=&DPI=190&SRS=EPSG%3A4326: Error (status=401) while reading the image from https:// xxxxx /wms?BBOX=93.59662362617522%2C-42.08234015699224%2C93.6671763738248%2C-41.97925984300776&HEIGHT=2375&WIDTH=1626&map_resolution=190&VERSION=1.1.1&FORMAT=image%2Fjpeg&SERVICE=WMS&format_options=dpi%3A190&LAYERS= iowasections&REQUEST=GetMap&STYLES=&DPI=190&SRS=EPSG%3A4326: Unauthorized
2016-12-09 08:11:53,971 ERROR [print.PDFCustomBlocks] - Error while adding a PDF elementjava.io.IOException: Error (status=401) while reading the image from https:// xxxxx /wms?BBOX=93.59662362617522%2C-42.08234015699224%2C93.6671763738248%2C-41.97925984300776&HEIGHT=2375&WIDTH=1626&map_resolution=190&VERSION=1.1.1&FORMAT=image%2Fjpeg&SERVICE=WMS&format_options=dpi%3A190&LAYERS= iowasections&REQUEST=GetMap&STYLES=&DPI=190&SRS=EPSG%3A4326: Unauthorized
Josh Obrecht, GISP
GIS Support and Research Facility
Iowa State University
213 Durham Center
613 Morrill Rd
Ames, IA 50011
515-294-6990
jobrecht@…662…
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
Sent: Friday, December 09, 2016 5:02 AM
To: Obrecht, Joshua D [DSN] <jobrecht@…662…>
Subject: Re: [Geoserver-users] Unauthorized Service
you should provide more details, like, the exact message you get, any error that might pop up
in the geoserver.log file when the request is made, and so on
On Thu, Dec 1, 2016 at 3:28 PM, Obrecht, Joshua D [DSN] <jobrecht@…662…> wrote:
I am trying to print a pdf through GeoServer. When I pass a layer from a service on the same server, the pdf populates with a message saying that the link is unauthorized. I have placed the localMatch dummy line into my yaml. I have also passed a valid user name and password when prompted. Is there something else that is needed in the yaml?
Josh Obrecht, GISP
213 Durham Center
613 Morrill Rd
Ames, IA 50011
515-294-6990
jobrecht@…662…
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
