Dear all,
I have issue when try to access layers from Remote Geoserver WFS using geoext and openlayers. It gave me an error message :
ows:Exception exceptionCode=“InvalidParameterValue” locator=“namespace”>
ows:ExceptionTextUnknown namespace [MapTab_helge]</ows:ExceptionText>
I can assure that I the workspace name and layers is correct. The geoserver(2.14) was setup by different person, then I try to access layers in my local geoserver using the same script and it’s working normal. Is there any configuration or authentication method which I should take a look?
Thank You
Regards
Muhammad Iqnaul
GIS, WebGIS, and Remote Sensing Specialist based in Indonesia
Sent from Mail for Windows 10
Dear
Are you sure you spelled the namespace correct? Namespaces are case sensitive….
Bart
Sent: zondag 12 januari 2020 15:36
To: GeoServer List geoserver-users@lists.sourceforge.net
Subject: [Geoserver-users] Unknown Namespace while trying to access WFS
Dear all,
Thank You
Regards
Muhammad Iqnaul
Dear all,
Hi Nuno,
Thank you for your reply, yes it turns out the issue was caused by authentication for the workspace. Any suggestions on put basic https auth in the header request?
On Mon, Jan 13, 2020, 4:23 PM Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
yes could be authentication related, it could also be that you are targeting a virtual service, without more details is hard to say.
On Sun, 2020-01-12 at 21:35 +0700, Muhammad Iqnaul Haq wrote:
Dear all,
Thank You
Regards
Muhammad Iqnaul
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
It depends on the client you are using, for example with CURL something like this should work (-u admin:geoserver):
curl -v **-u admin:geoserver** -XGET -H "Accept: text/xml"
http://localhost:8080/geoserver/rest/about/version.xml
On Mon, 2020-01-13 at 16:51 +0700, Muhammad Iqnaul Haq wrote:
Hi Nuno,
Dear all,
Thank You
Regards
Muhammad Iqnaul
Nuno Oliveira
experts!
@nmcoliveira
Software Engineer
Nuno Oliveira
experts!
Visit http://goo.gl/it488V for more information.
@nmcoliveira
Software Engineer
