[Geoserver-users] UPDATE: example of app-schema postgis the_geom column
I have some further clues on my problems with the geometry column of my PostGIS-based app-schema datastore. The syntax that I guessed previously was almost right:
Schema:
                     <element ref="gml:multiExtentOf">
                     </element>
Mapping File:
                             <AttributeMapping>
                                 <targetAttribute>
                                     gml:multiExtentOf
                                   </targetAttribute>
                                 <sourceExpression>
                                         <OCQL>the_geom</OCQL>
                                 </sourceExpression>
                             </AttributeMapping>
and I got this to work when I brought up a PostGIS-based app-schema datastore in an otherwise empty workspace. But the exact same configuration causes problems when the datastore is in the original workspace that has several other layers in it, including simple shapefile, PostGIS layers, and a shapefile-based app-schema layer. An additional weird thing is that when this happens, all GML3 service is broken, even on layers in other workspaces. But other formats, such as OpenLayers or GML2, are still OK (on the simple layers only, of course).
I haven't gone through all the perturbations yet on which combination of datastores in a workspace cause conflicts. Is this looking more like a bug and less like a user-error on my part?
Here is the response, with extra verbosity
<ServiceExceptionReport version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd&quot;&gt;
<ServiceException>
       java.lang.IllegalArgumentException: Type with same name already exists in cache.
Details:
org.geoserver.platform.ServiceException: java.lang.IllegalArgumentException: Type with same name already exists in cache.
  at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1304)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:240)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
  at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.IllegalArgumentException: Type with same name already exists in cache.
  at org.geotools.gml2.FeatureTypeCache.put(FeatureTypeCache.java:45)
  at org.geoserver.wfs.xml.v1_1_0.WFSConfiguration.configureContext(WFSConfiguration.java:233)
  at org.geotools.xml.Configuration.setupContext(Configuration.java:619)
  at org.geotools.xml.Encoder.<init>(Encoder.java:229)
  at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:137)
  at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:726)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
  ... 49 more
</ServiceException>
</ServiceExceptionReport>
