Using the REST interface, we update the bbox of a featuretype we recently created like this (pseudo code):
request_url = ‘/geoserver/rest/workspaces/someworkspace/datastores/somedatastore/featuretypes/somelayer’
xml = ‘somelayer’
request_url = request_url + ‘?recalculate=nativebbox,latlonbbox’
response = requests.put(request_url, data=xml)
This causes the featuretype to be disabled on disk, but enabled in memory. As a consquence, the layer disappears after restarting the server.
Only when we explicitly add true, the corrrect behaviour is observed.
Has anyone found this issue? Is a required field? Or is this a bug in GeoServer. We tried locating the serializer which writes the XML to disk, but were unsuccesful. If someone knows is, we’ll try our best at creating a pull request.
Thanks in advance,
Erik-Jan Vos - Nelen & Schuurmans B.V.
Sander Smits - Nelen & Schuurmans B.V.
On Wed, May 1, 2013 at 2:57 PM, Erik-Jan Vos <
erikjan.vos@anonymised.com> wrote:
request_url =
'/geoserver/rest/workspaces/someworkspace/datastores/somedatastore/featuretypes/somelayer'
xml = '<featureType><name>somelayer</name></featureType>'
request_url = request_url + '?recalculate=nativebbox,latlonbbox'
Only when we explicitly add <enabled>true</enabled>, the corrrect
Has anyone found this issue? Is <enabled> a required field? Or is this a
disk, but were unsuccesful. If someone knows is, we'll try our best at
It is a well known issue. Justin may be able to comment on this one... also
search the mailing list archives, there might already be something in it.
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Yes it is a known issue:
https://jira.codehaus.org/browse/GEOS-3964
On Wed, May 1, 2013 at 7:51 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Justin Deoliveira
OpenGeo - http://opengeo.org
On Wed, May 1, 2013 at 2:57 PM, Erik-Jan Vos <erikjan.vos@anonymised.com> wrote:
xml = ‘somelayer’
It is a well known issue. Justin may be able to comment on this one… also search the mailing list archives, there might already be something in it.
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
